OEM HQ - High Boost - Raise C/R D16A6 Which Gasket To Buy?
Old Apr 16, 2005 | 07:20 AM
W O T's Avatar
Default OEM HQ - High Boost - Raise C/R D16A6 Which Gasket To Buy?
Hey guys, Ive got the block all assembled now (vitaras on eagles with arp bolts) in a D16A6 engine with a built head thats milled .040
That will bring my compression to about 8.45:1, maybe a bit higher. Now Im looking to run about 15-18psi on this motor and I want to know which headgasket to buy to not only raise the comprssion a little, but will drop right in but can also take the abuse of 18psi with some copper spray and ARP headstuds
Any help, info would be appreciated
Thanks guys
Old Apr 16, 2005 | 04:06 PM
W O T's Avatar
Default Re: OEM HQ - High Boost - Raise C/R D16A6 Which Gasket To Buy? (W O T)
Old Apr 16, 2005 | 09:22 PM
USDM 4G VTEC's Avatar
stock are fine if installed correctly
btw
theres no need for copper spray if the block and head have been decked and cleaned
a good surface will provide good seal
theh copper is used to "fill" the small imperfections on the surface when they arent serviced when installing a new gasket
Old Apr 16, 2005 | 09:41 PM
W O T's Avatar
Default Re: OEM HQ - High Boost - Raise C/R D16A6 Which Gasket To Buy? (USDM 4G VTEC)
Ok what gasket will lower the compression the most?
HPfreak
Sep 23, 2011 04:53 PM
Blue94Accord
Oct 23, 2010 04:00 PM
realis9
Feb 3, 2006 10:13 PM
rmcdaniels
Nov 23, 2005 11:45 AM
GSRacer
Oct 15, 2001 08:09 AM
