broken crank pulley bolt ....
Old Apr 15, 2005 | 05:57 PM
jdmstreethatch's Avatar
Default broken crank pulley bolt ....
okay so my buddy was taking off the crank pulley bolt on my gsr motor and it snapped off. any idea on how fucked i am?
i dont know how long the bolt is but there is about 3/4" of thread plus the head of the bolt that snapped out. im hoping a machine shop can fix this.
thanks
chris
Old Apr 15, 2005 | 07:09 PM
alpine_hikr's Avatar
I am guessing that the crank pulley is now stuck on the motor? You might have to have somebody weld a nut on the end of it to get it out, or use some kind of bolt extractor. I wouldnt try drilling it out because then you run the risk of ******* up your crank. Good luck
Old Apr 15, 2005 | 08:09 PM
no the crank pulley came off because there is no bolt to hold it on. it broke off inside the motor.
Old Apr 15, 2005 | 08:45 PM
PrettyLude's Avatar
drop the crank and bring it to the machine shop, they should be able to take it out for u
Old Apr 15, 2005 | 08:56 PM
im hoping they dont have to take apart the motor. im just gonna take em the whole thing
Old Apr 22, 2005 | 08:51 AM
CRXified's Avatar
Default Re: (jdmstreethatch)
im worried about breaking mine off cause its being a bitch to break loose. it probably was never off before and i heard heating it can cause **** to go wrong and damage the bearings and warp the crank pully. is this true?
Old Apr 22, 2005 | 11:29 AM
mrDFWmechanic's Avatar
just take it to a machine shop and they'll get it out
Old Apr 22, 2005 | 09:12 PM
strongreaction's Avatar
Default Re: (CRXified)
heat will wreck the seals, but your bearings should be ok if you don't really cook it...
kulo
May 13, 2013 06:32 AM
bradley
13
Jan 9, 2012 02:12 PM
barrera
Oct 11, 2010 07:17 AM
goldfinger93030
Feb 13, 2010 06:39 AM
