High and erratic idle
Old Apr 15, 2005 | 08:10 AM
honda95civic's Avatar
Default High and erratic idle
searched but need more assistance
its been about a year and half now and its drivin me nuts.. i replaced the IAC and it fixed it for about a week.. then back to the messed up revin idle in park and neutral (its not happening in drive and reverse)
no leaks that i can see
replaced iac
replaced coolant temp sensor
Should i flush and refill my coolant to make sure there is no air bubbles.??
TPS?
Does any place like autozone do diagnostics for free? if not how much?
Idles at 1400 to 2000 when reving.. and when it doesnt rev on its own in drive(sometimes-usually when i first start drving before it gets warmed up completey its at 1200-1500.. i want it down to like 800.. how can i do that???
Starting to bog when i let off the gas sometimes
at stop signs it will want to stall but when i hit the gas its fine?
driving me nut?
btw.. where can i get a good fuel filter? i saw aem for like 110.. but how bout stock or something from pepboys?
Old Apr 15, 2005 | 08:26 AM
hondapwr's Avatar
Default Re: High and erratic idle (honda95civic)
I use a regular Pur-o-lator fuel filter on my Civic with a B16, and I have no problems with fuel flow. It probably makes around 175HP at the fly with the mods I have.
Start checking your vacuum lines for starters. After that, get a Helms manual and a multimeter and start checking your TPS + other related sensors.
Old Apr 15, 2005 | 10:44 AM
Default Re: High and erratic idle (hondapwr)
Not to sound dumb, But how do i go about checking the TPS? I have a helms manual so ill look in there.. but want some other views as well
and how much did ur fuel filter cost??
phatbuddha
May 20, 2013 10:46 AM
chogunna91
Dec 12, 2010 02:51 PM
stevescivic
Mar 22, 2008 08:43 AM
Mr. Eric
Feb 2, 2005 06:16 AM
maxxdout
Jun 21, 2002 06:04 AM
