is my timing messed up ??
Old Apr 14, 2005 | 11:07 PM
CIVIC96DXcp's Avatar
Default is my timing messed up ??
i have this weird - chatter like sound - when my car is under heavy load, especially high RPM. also, i lost a lot of power at high RPM, it seems like my car bog down. i thought my clutch was slipping, but then i ask my automotive teacher, and he said that my best bet would be the timing. he was saying something about the fuel does not properly burnt, and my lost of power would be the result from it. however, if my clutch does not engage ( if i rev the car when in neutral, the noise goes away.)
what do you guys think? thanks for the input in advance.
Modified by CIVIC96DXcp at 12:18 AM 4/15/2005
Old Apr 15, 2005 | 01:11 AM
kkim's Avatar
Default Re: is my timing messed up ?? (CIVIC96DXcp)
check your timing to be sure...
http://www.c-speedracing.com/h...g.php
Old Apr 15, 2005 | 09:47 AM
should i go local shop to check the timing?
Old Apr 15, 2005 | 09:51 AM
POE's Avatar
POE
timing gun will help you out, what about your teacher, have his *** help you.
Old Apr 15, 2005 | 10:16 AM
turbo_b16_ex's Avatar
could be ur bearings. check the ingition timing 1st. how long has it been doing this. have u replaced ur spark plugs
Old Apr 15, 2005 | 04:26 PM
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">timing gun will help you out, what about your teacher, have his *** help you.</TD></TR></TABLE>
yeah, his *** will help me possibly on tuesday, however it is still uncertain. his *** was suppose to help me on thursday's class, but it was all theory class. so i gotta wait until tuesday. how expensive is a timing gun?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">could be ur bearings. check the ingition timing 1st. how long has it been doing this. have u replaced ur spark plugs</TD></TR></TABLE>
it has been doing this since the first time i bought the car. approx. 4 weeks ago.
i have replace my plugs and wires. so that's out.
thanks for the suggestion guys
Old Apr 15, 2005 | 08:31 PM
has the sound been progressivly getting louder?
Old Apr 16, 2005 | 09:29 AM
not really. it sounds like a loose bearing or something, but my teacher said it sounds like the fuel does not burnt properly. the thing is, if i go WOT, the car does not pull at all, it does not have power. i compared my car to my friends, with the same car, same year and mileage, and his pulled way stronger than mine.
Old Apr 16, 2005 | 06:07 PM
well if it is fuel, u can try running some sea foam through ur vacuum lines and your fuel system. u can pick it up at any auto store.
Ran4it2
Jun 11, 2009 11:46 PM
stevn
Nov 20, 2008 12:06 PM
Lewy. Dee Ayy
Mar 23, 2006 03:30 AM
nick32
Dec 28, 2005 01:48 PM
