cel code 41 after b18b swap
check your shock tower harness where the wires for the 02 sensor go in... i accidentially bent one of the pins inside of the plug and it threw that code... check the wiring from the o2 sensor to the ecu and everything.... before replaceing your 02 bc they are expensive
i notice that when I get on the gas my temp gauge goes up and down. It doesnt go up more than half way so thats a good thing. Could that be connected to my cel problem too.
Code 41 is for the O2 heater - its inside the actual O2 sensor and helps to warm it up quicker as O2 sensors don't spit out a voltage until they reach 600*F.
You need a multimeter to measure the resistance of the heater element (between the two black wires) - should be 15-40 ohms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr_tony_montana »</TD></TR><TR><TD CLASS="quote">i notice that when I get on the gas my temp gauge goes up and down. It doesnt go up more than half way so thats a good thing. Could that be connected to my cel problem too.</TD></TR></TABLE>
could it cause this to happen?
My 97 DX coupe has the same CEL and Yes! I replaced 02 sensor twice and still comes back. I still get 35 mpg on it, hehe
my girls car has the same exact problem, oh well it still runs perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">My 97 DX coupe has the same CEL and Yes! I replaced 02 sensor twice and still comes back. I still get 35 mpg on it, hehe</TD></TR></TABLE>
wth? well how does this come about...cause I know I would go insane seeing that thing light up but I've read others grow seeing the CEL...but if thats the case what can be done?
Make sure the engine you swapped in actually has a heated o2 sensor. Check how many wires are coming out of it... if it only has one, you have a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">Make sure the engine you swapped in actually has a heated o2 sensor. Check how many wires are coming out of it... if it only has one, you have a problem.</TD></TR></TABLE>
What wires are you talking about?
Thanks
Thanks
924drb20
Dec 14, 2010 10:36 AM
memorybox
May 27, 2007 08:19 PM
SystemGSR
Jun 3, 2002 09:56 PM
