b16a2 in ek, engine surge, please help...
Old Apr 14, 2005 | 11:33 AM
EK9 B16B TSL's Avatar
Default b16a2 in ek, engine surge, please help...
ok i have a 96 civic cx running a 99 b16a2 with the 96 cx harness and an obdII p72. The car idles fine and the wiring is all good. The problem is when i hold throttle down a tiny bit, as to keep the rpm's at 1500 or 2000, the engine surges from like 1400 to 1800. it doesnt do this if i push the pedal down farther. This real annoying like when im in traffic or trying to go slow over bumps. anybody have any ideas?
Old Apr 14, 2005 | 05:38 PM
Default Re: b16a2 in ek, engine surge, please help... (EK9 B16B TSL)
bump, nobody knows??
Old Apr 14, 2005 | 05:40 PM
e jay one's Avatar
check the timing. does it sputter or just jump up and down?
Old Apr 14, 2005 | 05:42 PM
butters's Avatar
i had the same problem with the same swap and chassis. except i was using a p73. it started to happen out of nowhere. what i did was unplug/pulg the ecu, then took off the neg. on the battery to reset the ecu. the problem dissapeared. GL to you
Old Apr 14, 2005 | 05:46 PM
conekiller's Avatar
As someone stated reset the ECU.
Old Apr 14, 2005 | 05:48 PM
PureBlood's Avatar
could be as simple as your ecu needs a reset, that or there's two little bolts that go on either side of where the throttle cable bolts to the bracket on the intake mani, take a look if there's a gap, then that "Surge" you speak of could be one of the boltsgoing from crooked to flat on the bracket
Old Apr 14, 2005 | 06:32 PM
Mr. Em1's Avatar
yeah man, go and reset that ecu and see what happens from there. good luck with that man
Old Apr 15, 2005 | 08:34 AM
I reseted the ecu 3 times and it still surges. The throttle cable is bolted on tight too. I noticed that it doesnt do it until the car has been running for about 15 seconds... could it be a bad sensor? the cel isnt on either.
Old Apr 15, 2005 | 08:58 AM
shifty35's Avatar
Default Re: (EK9 B16B TSL)
Did you properly set the TPS? .5v at full close, 4.5v at WOT.
Old Apr 15, 2005 | 09:34 AM
Phatch99's Avatar
Default Re: (shifty35)
could be your iac?
Old Apr 15, 2005 | 10:18 AM
PureBlood's Avatar
are your throttle body coolant lines bypassed?
Old Apr 17, 2005 | 04:55 AM
Default Re: (PureBlood)
ill check that today, thanks...
Old Apr 17, 2005 | 06:07 AM
EVIL Hx Coupe's Avatar
Did you bleed the air out of your cooling system??? I had a slight idle surge on my car when the first day after swapping and it was because I had alot of air in my coolant. It's not common, but something else you could check.
Old Apr 17, 2005 | 04:12 PM
Default Re: (EVIL Hx Coupe)
i think its ok but i'll check it, thanks man
Old Apr 17, 2005 | 04:18 PM
funvtec's Avatar
same issue here in a 97 dx hatch with a p30 ecu and a b16a3
any info i'd like to know too
if i'm right car runs perfect just goes up and drops off repedeally?
Old Apr 17, 2005 | 04:19 PM
Lmgrcivic's Avatar
check the TPS sensor most of the time thats that problem it starts to go bad but it wont throw a cel
Old Apr 17, 2005 | 04:51 PM
Dc_Ek's Avatar
Check the TPS and the Idle Air Control valve
Old Apr 19, 2005 | 08:09 AM
Default Re: (Dc_Ek)
my engine only has 45k on it, do you think the tps or iacv could have gone bad that fast?
Old Apr 19, 2005 | 09:12 AM
Capt. Jimbo McSubipants's Avatar
my b16a3 did the same thing as well...and i'm almost postive it was my tps...cause the casing was broken never did throw up a CEL ethier..just did that stupid idle....so i'd go with your TPS on this one....gl with that..
Old Apr 19, 2005 | 02:49 PM
Default Re: (b16delteg)
thanks guys, ill look up how to test the tps, hopefully that will be it...
TheMightySi
Nov 16, 2010 08:07 PM
Nate047
Feb 20, 2007 11:36 AM
five_wang05
24
Sep 24, 2005 09:38 AM
Mr.Civic
Jan 14, 2005 05:45 PM
