Clutch is smooth when car is cold but when driven/warmed up it squeeks ??
Old Apr 14, 2005 | 10:44 AM
xunkn0vvnx's Avatar
Default Clutch is smooth when car is cold but when driven/warmed up it squeeks ??
Why is it that in the mornings or the afternoons when I first hop into the car, the clutch is smooth during its full throw, but after some driving the clutch pedal starts to squeek and stick at the end of the throw becoming pretty squeeky and full of friction making it hard to drive well ??
Old Apr 14, 2005 | 11:14 AM
totsie7944's Avatar
Default Re: Clutch is smooth when car is cold but when driven/warmed up it squeeks ?? (xunkn0vvnx)
hmmm mine is the opposite. In the morning it squeaks usually on the first take off but after its warmed up everything is fine. I know squeaking is normal in MANY clutches however, so you might be fine. Do you launch hard? what rpm?
Old Apr 14, 2005 | 11:43 AM
xunkn0vvnx's Avatar
this is just daily driving, shifting anywhere from 3-3.5 k, i have yet to launch my car
Old Apr 18, 2005 | 09:39 AM
xunkn0vvnx's Avatar
Default Re: (xunkn0vvnx)
How much is a good price for a dealer to take out of the tranny and lube the clutch fork ?? Im at 60k miles and have yet to change the clutch, is now a good time ?? No slipping whatsoever though.
Old Apr 18, 2005 | 11:01 AM
totsie7944's Avatar
dealerships are gonna rip you hardcore on price. prolly $500 just to take down the tranny alone.
Old Apr 18, 2005 | 12:07 PM
JoNNiE's Avatar
Default Re: (totsie7944)
I have the same symptoms on my car. When the clutch starts to squeek it seems likes its harder to drive smoothly. I have also noticed that my clutch is starting to slip at 4k rpms. Maybe it has something to do with the squeek?
Old Apr 20, 2005 | 09:19 AM
xunkn0vvnx's Avatar
this clutch squeek and weirdness is bothering me, should i just go ahead and change the clutch ?? How much is a clutch change ??
Old Apr 20, 2005 | 09:28 AM
GRAVEDIGGER's Avatar
Not a ITR but a B16 with fidanza flywheel and a new ITR clutch/pp less than 5k ago.
Same thing, car is fine when cold and after about 45 min it squeeks and gets a little sticky when it is all the way near the floor, within 3/4 inch or so. ^^^ for a fix.
Old Apr 21, 2005 | 09:57 AM
EJ2-Fluffy's Avatar
Default Re: Clutch is smooth when car is cold but when driven/warmed up it squeeks ?? (GRAVEDIGGER)
Im guessing the '97 type-r uses a hydraulic transmission. I would go ahead and put some new lubricant into the clutch piston shaft.
Perhaps get the clutch spring replaced? (could be, but u said it only happens when driving it)
Could be your throwout bearing or the spring came loose on the pressure plate forcing it on the clutch.
Here are some threads I found:
https://honda-tech.com/zerothread?id=682813
https://honda-tech.com/zerothread?id=524265
Goto Search and check the archives radio button and type in "Squeaky clutch" so many posts on it.
Good luck on the project,
J Muck
Old Apr 21, 2005 | 12:02 PM
xunkn0vvnx's Avatar
Default Re: Clutch is smooth when car is cold but when driven/warmed up it squeeks ?? (CRX-Fluffy)
Thanks J Muck my fellow SJB Brave , still have your crx ??
Its Jeff Mag... what have you been up to ?? Wanna come by and help me fix my squeaky clutch problem one of these days ??
Old Apr 21, 2005 | 12:09 PM
Lifter2012's Avatar
Default Re: Clutch is smooth when car is cold but when driven/warmed up it squeeks ?? (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm mine is the opposite. In the morning it squeaks usually on the first take off but after its warmed up everything is fine. I know squeaking is normal in MANY clutches however, so you might be fine. Do you launch hard? what rpm?</TD></TR></TABLE>
&lt;---- same thing as totsie
Old Apr 21, 2005 | 12:43 PM
Rene M's Avatar
Default Re: Clutch is smooth when car is cold but when driven/warmed up it squeeks ?? (Lifter2012)
More than likely we all have the same problem of clutch dust on the input shaft slide tube. A ITR does not have a duct cover on the lower end it actually has a rather large chunk of aluminum that is removable. If you pull it off and use an air blower you can blow a bunch of the dust out and lube up the slide tune with a dry film graphite compound that will not attract the dust like say wd40.
I would use a bit of brake clean to clean then the graphite but both can be used in aerosol form to make things easy.
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Jan 24, 2019 08:24 PM
stevenDAtegra
Transmission & Drivetrain
Jun 25, 2009 04:12 PM
xunkn0vvnx
Apr 20, 2005 01:21 PM
Flux
Nov 26, 2003 11:25 PM
brucie
Jul 12, 2003 11:23 AM
