rebuilding gsr shortblock
I have a 98 gsr shortblock which im planning on rebuilding. I bought this block a few moths ago with the pistons/rods taken out. The crankshaft is still installed and obvious the oil pan is removed. How much am I looking to spend to have the crank bearings, rod bearings replaced and also changing the pistons rings. Is all this necessary? If so which brand should I use and again how much should this work cost? Im not to familiar with internal engine work so this is why I need a heads up.
I'm going to be rebuilding a shortblock this summer. It'll be my first time. Replace all the bearings. You should have the block honed too. I'd at least find a buddy that has done internal work to show you how to do it.
So taking the block to a mechanic shop is not necessary? I was under the impression that it was a difficult task that requires hard work. How much do these bearings and rings go for? OEM or aftermarket?
cityofcaterpillars
Engine Machining & Assembly
Jul 19, 2016 05:10 AM
b16bri
Oct 11, 2010 05:39 PM
averyvm
Apr 14, 2007 07:06 PM
