trying to put B18c1 pistons and rods (p72) into aB18A1 block
well I put the pistons into the block but I used the bought oem bearings for the b18a with the numbers from the GSR thinking that they would be the same. when I put in the bearings I thought that was the way that It was supose to be so I installed all but one piston, then a friend looked at the bearing and told me cant use those bearings so what should I do
Re: trying to put B18c1 pistons and rods (p72) into aB18A1 block (averyvm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averyvm »</TD></TR><TR><TD CLASS="quote">well I put the pistons into the block but I used the bought oem bearings for the b18a with the numbers from the GSR thinking that they would be the same. when I put in the bearings I thought that was the way that It was supose to be so I installed all but one piston, then a friend looked at the bearing and told me cant use those bearings so what should I do</TD></TR></TABLE>huh??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohf »</TD></TR><TR><TD CLASS="quote">get a GSR/ITR crank </TD></TR></TABLE>im glad at least one person seems to know what he was asking
Comp97GSR
05-18-2012 07:17 PM
white4doorsi
07-06-2008 01:05 PM
richeybrooks
11-19-2004 10:43 PM
