one man brake bleeder kits
Old Apr 13, 2005 | 06:23 PM
tca0bell's Avatar
Default one man brake bleeder kits
do these things actually work?? anyone usem?
Old Apr 13, 2005 | 06:26 PM
Kyles ej1's Avatar
Default Re: one man brake bleeder kits (tca0bell)
my guess would be no cuz u gotta have someone open and close the nipple valve thing but then again i dont know how it works
Old Apr 13, 2005 | 06:27 PM
pdiggitydogg's Avatar
Yes
I have a vaccum pump style kind and its great
(the motiv bleeder isnt that great though...not at all worth the money)
Old Apr 13, 2005 | 06:28 PM
nerdsports's Avatar
maybe the kit includes a check valve so no air gets back into the lines?
imma need to find something like this soon, gonna install all four gsr disc brakes on my car...
in other words.... BUMP.
ohboy95c's Avatar
Default Re: one man brake bleeder kits (ineedaswap)
we have one and nobody uses it. It doesn't take long to ask somone to pump the brakes a dozen times.
Old Apr 13, 2005 | 06:31 PM
bsixteenhatch's Avatar
i have one at the shop i work at and you pump it to create pressure in the lines, just like pressing the pedals. mine just clamps to the master cylinder resivoir and then a line comes off that to a hamd pump
Old Apr 13, 2005 | 06:33 PM
tca0bell's Avatar
Default Re: one man brake bleeder kits (ohboy95c)
the directions said something about keep pumping it untill u see no air in the lines. so im guessing the line is long enough so that when there is only clear fluid with air bubbles and u let off the brake itll only suck back in fluid with no air. its kinda hard to explain.
Old Apr 13, 2005 | 07:10 PM
B2FiNiTY's Avatar
Those kits suck from my personal experience. It is no better than just using the tubing.
Old Apr 13, 2005 | 07:51 PM
civiccoupe94's Avatar
dont waste your money... how hard is it to just call up a buddy or neighbor to pump your brakes for you for 5 minutes of their time....
Old Apr 13, 2005 | 08:02 PM
cxSHOE's Avatar
used the motiv one... (also following the write up on h-t that someone did that gives you a great seal on the top of the resevour.. dont ask me i forget who did the write up, do a search in the archive)
5 brake bleeds, works perfectly fine..
Old Apr 13, 2005 | 08:25 PM
tca0bell's Avatar
Default Re: one man brake bleeder kits (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">used the motiv one... (also following the write up on h-t that someone did that gives you a great seal on the top of the resevour.. dont ask me i forget who did the write up, do a search in the archive)
5 brake bleeds, works perfectly fine..</TD></TR></TABLE>
searched, cant find it.
B_Swapped93
Apr 27, 2014 08:54 AM
dank24
11
Apr 2, 2007 09:26 PM
funkfnamna
Mar 2, 2005 08:44 PM
blaze1987
May 20, 2004 04:07 AM
hellas
Jun 10, 2003 05:37 AM
