HELP CEL AND ECU!!!!
Old Apr 13, 2005 | 04:28 PM
Thundakat85's Avatar
Default HELP CEL AND ECU!!!!
ok, my CEL came on, on my way home tonight. i got it parked, left it running and pulled up my carpet. looked at the lcd light on my ECU. it blinked a 1 SHORT then paused then 20 SHORT in a row. is it throwing me engine code 1 and 20? of the list shown here?
https://honda-tech.com/zerothread?id=978933
Old Apr 13, 2005 | 06:25 PM
DocSean's Avatar
since the long flash designates the first number (i.e. the 1 in 10, the 2 in 23, the 3 in 38) and the short flash designates the second number (i.e. the 2 in 12, the 5 in 15, or the 4 in 24) it doesn't really seem to make sense that your ECU should ever blink 20 short; It should instead blink 2 long to signal a code 20. Double check your ECU.
Old Apr 14, 2005 | 07:03 PM
i looked at it for a good 5 or 6 minutes. it did it quite a few times. did this while the car was still running and while the CEL was still on, on my gauge cluster
Old Apr 14, 2005 | 07:24 PM
doublethink's Avatar
Default Re: HELP CEL AND ECU!!!! (Thundakat85)
the one short blink is the POST of the ecu itself, thats normal.
the 20 short? i doubt that. gotta double check it, if all else fails, pull the hazard fuse for about 5 minutes to reset the ecu and just pray.
Old Apr 14, 2005 | 08:06 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: HELP CEL AND ECU!!!! (doublethink)
what kinda car is it? still stock? the stock codes u describe are 1 and 20 witch are the O2 sensor and the ELD (electric load detector) O2 sensors get lazy after 60K+ miles and should be replaced. eld i dont know i need more info.
Old Apr 14, 2005 | 08:07 PM
DieMaster's Avatar
Default Re: (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote"> It should instead blink 2 long to signal a code 20. Double check your ECU.</TD></TR></TABLE>
not if he's still obd2. what u describe is 92+ obd1 cars.
Old Apr 14, 2005 | 08:11 PM
mr. carpenter's Avatar
Default Re: (DieMaster)
code 1 is oxygen content
code 20 is electric load.
as stated.
Old Apr 14, 2005 | 08:53 PM
DocSean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">
not if he's still obd2. what u describe is 92+ obd1 cars.</TD></TR></TABLE>
whoop, overlooked that fact. obd0 and obd1 are same correct? obd2 is the oddball?
Old Apr 17, 2005 | 01:04 PM
all i know is i have a 91 EF hatch, D15b2 stock motor, DPFI. not sure about all the 0BDI and 0BdII stuff
92DAB16A
Sep 14, 2012 07:14 PM
efjones9
Oct 1, 2008 04:28 PM
jochy212
May 15, 2008 11:33 AM
ozzyman
Jan 3, 2006 05:27 PM
raene
May 27, 2001 12:33 AM
