Good amp to power an Alpine 12"
Old Apr 12, 2005 | 07:44 PM
.David's Avatar
Default Good amp to power an Alpine 12"
http://www.crutchfield.com/S-b...PM350
Could this amp handle a 12" Alpine type R? I have read that the sub handles 50-500rms...and the amp is 350rms
Old Apr 13, 2005 | 08:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: Good amp to power an Alpine 12" (TurboDaveR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDaveR &raquo;</TD></TR><TR><TD CLASS="quote">http://www.crutchfield.com/S-b...PM350
Could this amp handle a 12" Alpine type R? I have read that the sub handles 50-500rms...and the amp is 350rms</TD></TR></TABLE>If it's a SWR1222D- DVC 2OHM you would have to wire the VCs in series for a 4OHM load and that amp puts out 200watts at 4OHMs, if it's a SWR1242D- DVC 4OHM you can wire the VCs in parallel, [much better] for a 2OHM load and the amp puts out 350watts into a 2OHM load, but both speakers are 500watts RMS and 1500watts peak. so I would say you are underpowering them by a lot, remmember it's better to be overpowered then underpowered, you realy need an amp that will give you at least 500watts RMS into whatever load you are running, you also need an amp that is stable at that load, [impedance] there some amps out there that are stable down to 1OHM so if you have the SWR1222D DVC 2OHM, you could wire the VCs in parallel for a 1OHM load. 94
Old Apr 15, 2005 | 07:45 PM
SuckMyDOHC's Avatar
it COULD, but this amp would be better... http://www.bestbuy.com/site/ol...50996
Old Apr 16, 2005 | 07:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: (SuckMyDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">it COULD, but this amp would be better... http://www.bestbuy.com/site/ol...50996</TD></TR></TABLE> Only 50watts more, 250watts, still underpowering a 500watt sub. 94
Old Apr 16, 2005 | 11:22 AM
SuckMyDOHC's Avatar
its 2 ohm stable and you could have that sub running at 2 ohms, so then it'd be anywhere from 400 to 600 watts rms
Old Apr 16, 2005 | 04:20 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">its 2 ohm stable and you could have that sub running at 2 ohms, so then it'd be anywhere from 400 to 600 watts rms</TD></TR></TABLE> Yes at 14.4V car has to be running, and alt. has to put out 14.4V and the amp has to see that 14.4V at the end of the power wire, don't get me wrong, I agree it's a better amp, but I am a firm beliver of more power is better, [better to be overpowered then underpowered] 94
Accord1234
Audio / Security / Video
Feb 14, 2008 05:05 AM
TANKE92113
12
Feb 6, 2007 01:59 PM
thatasiankidtony
Sep 23, 2006 04:23 PM
Orpheus1985
Jul 31, 2005 04:11 PM
89hbcivicguy
Mar 3, 2005 09:12 AM
