Part number for DOHC del sol or 99-00 Si air conditionn - A/C bracket?
Old Apr 12, 2005 | 05:22 PM
Fuster_Cluck's Avatar
Default Part number for DOHC del sol or 99-00 Si air conditionn - A/C bracket?
Anyone have this # off hand?
Is it included with #15 because I don't see a number for the actual bracket --> HERE
Old Apr 12, 2005 | 08:01 PM
BlueIntegraBoy's Avatar
Default Re: Part number for DOHC del sol or 99-00 Si air conditionn - A/C bracket? (Hybrid93Hatch)
38930-P30-000 Del Sol VTEC/Civic Si BRACKET, COMPRESSOR (#1 in the pic below)
Old Apr 13, 2005 | 06:12 AM
Shaun's Avatar
I have the 99-00si A/c bracket if you want to buy it .... you trying to get a/c ? it wont work if your trying to re use your a/c
Old Apr 13, 2005 | 06:25 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Shaun)
Don't WASTE your money - buy the CHEAPER 1997 CR-V a/c bracket.
Old Apr 13, 2005 | 07:03 AM
FOC-US2K's Avatar
Default Re: (B18C5-EH2)
If you want to keep you power sterring and dont have one of the extended deck height blocks (aka b18c or b20) you need the delsol bracket. If you have one of the extended deck height blocks than the crv bracket will work.
Here are the part numbers:
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
Old Apr 13, 2005 | 07:10 AM
eg crunkmonster's Avatar
Default Re: (FOC-US 2K)
http://www.slhonda.com tells u all the part numbers and lets u click the number on the picture so u can get t]he right part
Old Apr 13, 2005 | 07:56 AM
dwnthehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOC-US 2K &raquo;</TD></TR><TR><TD CLASS="quote">If you want to keep you power sterring and dont have one of the extended deck height blocks (aka b18c or b20) you need the delsol bracket. If you have one of the extended deck height blocks than the crv bracket will work.
38930-P54-000 Del Sol Bracket</TD></TR></TABLE>
This is correct. I learned the hard way.
Old Apr 21, 2005 | 11:25 AM
nojoke's Avatar
Default Re: (dwnthehatch)
If I get the CRV part number 38930-P7J-000 CRV Bracket then i'll be able to use my Civic Compressor and keep power steering? I have a B18, by the way.
I want to make sure I order the correct bracket from Honda. So the only difference between the CRV bracket and the Del Sol bracket is the price? Taking into consideration that I have a B18. From what i've gathered, if I had a B16 then I would NEED the Del Sol Bracket. Thanks.
Old Apr 22, 2005 | 06:30 AM
nojoke's Avatar
Default Re: (nojoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nojoke &raquo;</TD></TR><TR><TD CLASS="quote">If I get the CRV part number 38930-P7J-000 CRV Bracket then i'll be able to use my Civic Compressor and keep power steering? I have a B18, by the way.
I want to make sure I order the correct bracket from Honda. So the only difference between the CRV bracket and the Del Sol bracket is the price? Taking into consideration that I have a B18. From what i've gathered, if I had a B16 then I would NEED the Del Sol Bracket. Thanks.</TD></TR></TABLE>
Can anybody chime in on this? Thanks.
Old Apr 22, 2005 | 06:43 AM
FOC-US2K's Avatar
Only the b18c and b16b motors have the extended
deck height motor. So with a b18b you would need the delsol bracket to keep your ps.
Old Apr 22, 2005 | 10:46 PM
BANting's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Don't WASTE your money - buy the CHEAPER 1997 CR-V a/c bracket.
I have one for sale Pm me if your interested ill give it to you for a good price its brand new
IMPATIENT
Mar 22, 2006 06:46 AM
yh23
Aug 10, 2005 11:16 PM
forcefedish
Jun 1, 2005 08:47 AM
jdm jedi
Sep 14, 2003 03:21 PM
J_SpeC_EK
Mar 20, 2002 07:54 AM
