ARP HEADSTUDS TORQUE QUESTION
Old Apr 12, 2005 | 03:09 PM
juanb's Avatar
Default ARP HEADSTUDS TORQUE QUESTION
Does anyone have any experience with using arp headbolts. I have to replace my headgasket, and just purchased arp headbolts. The only thing i am concerned with is that as i am searching i see differnt answers as to how much to torque them. I have read to over torque the bolts from 5-20 ft. lbs. more. Does anyone have any experience with the arp headbolts? please post how much u torqued them to and how well it worked. thank you guys.. btw..im replacing it with a stock headgasket
sorry for long post. just concerned
Old Apr 12, 2005 | 03:15 PM
modedicebox's Avatar
Default Re: ARP HEADSTUDS TORQUE QUESTION (juanb)
bump
because im in the same boat
Old Apr 12, 2005 | 03:16 PM
Luserkid's Avatar
Your best bet would be to call ARP directly and ask them for the spec. You dont want to **** that up. But the key thing is to do the 3 step torque.
20lbs
45lbs
final tq.
Also in this order:
1 7 9 5 3
4 6 10 8 2
Old Apr 12, 2005 | 03:21 PM
komat's Avatar
Default Re: ARP HEADSTUDS TORQUE QUESTION (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet would be to call ARP directly and ask them for the spec. You dont want to **** that up. But the key thing is to do the 3 step torque.
20lbs
45lbs
final tq.
Also in this order:
1 7 9 5 3
4 6 10 8 2
arnt you suppose to start from the middle?
i think the way you have listed is to take off the head
Old Apr 12, 2005 | 03:27 PM
user 98292739's Avatar
you hvae it in the wrong order....the order you stated is to take the head off....when you put the head back on you start from the middle
and then out then middle then out again..or soemthing but what you stated is wrong...
with the arp stud it will say when you get them..i got arps for d16z6 and the sheet for me says 60lbs torque...factory is 49.
LShatchie's Avatar
Default Re: ARP HEADSTUDS TORQUE QUESTION (komat)
yeah your supposed to start from the middle and work outward
Old Apr 12, 2005 | 03:29 PM
juanb's Avatar
Well i just called arp and the guy told me to torque them down to 65-70 ft. lbs USING THEIR MOLY LUB!
Old Apr 12, 2005 | 03:39 PM
what kind of motor? im guessing a b right? 60 lbs was for my D sorry
Old Apr 12, 2005 | 05:24 PM
juanb's Avatar
its a b18c5
vti_civ
Jan 24, 2019 02:23 AM
djtony5
Nov 17, 2005 02:48 PM
The Jacko
Aug 12, 2005 08:29 AM
omgwtfhaxnub
Jan 23, 2005 05:50 PM
