Weird sound coming from engine bay?
Old Apr 12, 2005 | 09:16 AM
dawrenn's Avatar
Default Weird sound coming from engine bay?
I have a 99 Civic Ex with 95,xxx miles. When the car is on there is a weird sound coming from the drivers side of the engine bay. It is kind of like a wining sound or like something needs to be oiled. It seems like it is coming from one of the belts/pulleys because the sound goes with the pulley turning. What do you think it could be? If there is anything I left out please let me know and I will post it.
TIA,
David
Old Apr 12, 2005 | 09:18 AM
suckawillis's Avatar
Default Re: Weird sound coming from engine bay? (dawrenn)
need more info
Old Apr 12, 2005 | 09:25 AM
dawrenn's Avatar
Default Re: Weird sound coming from engine bay? (suckawillis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">need more info
Like what? Here goes nothing. I have A/C and Power steering. My dad says it could be the alternator(sp?) It only does it when the car is sitting that I know of, I am not sure if it is doing it when I am driving. I can hear it when I am sitting in the car. The sound is like if a wheel was bent, you would hear it when it goes to the spot that is bent. I know that is not the best description that is the only thing I could think off. Let me know if you need more info
Old Apr 12, 2005 | 12:25 PM
Contraband's Avatar
hey, i know. i bet its a cat.
Old Apr 12, 2005 | 12:42 PM
IHateJDM's Avatar
Default Re: (LS95eg)
tighten your belts
Old Apr 12, 2005 | 01:36 PM
idriveadelsol7's Avatar
Default Re: (IHateJDM)
it's probably your turbo spool
Old Apr 12, 2005 | 02:15 PM
97jdmek's Avatar
Default Re: (deLasoL7)
your timing belt is loose. just tighten it and the sound shoud go away
Old Apr 12, 2005 | 03:12 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deLasoL7 &raquo;</TD></TR><TR><TD CLASS="quote">it's probably your turbo spool </TD></TR></TABLE>
I wish I had turbo.
Old Apr 12, 2005 | 03:18 PM
tsjeff's Avatar
Default Re: (dawrenn)
if its a hissing sound, it might be the water pump about to go out. hope this helps, i dont know what type of sound your talking about
Old Apr 12, 2005 | 03:19 PM
dawrenn's Avatar
Default Re: (9 3 d e l s o l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l &raquo;</TD></TR><TR><TD CLASS="quote">if its a hissing sound, it might be the water pump about to go out.</TD></TR></TABLE>
Its not really a hissing sound.
Old Apr 12, 2005 | 03:21 PM
tsjeff's Avatar
could it be oil/liquid on the belts?
Old Apr 12, 2005 | 03:24 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l &raquo;</TD></TR><TR><TD CLASS="quote">could it be oil/liquid on the belts?</TD></TR></TABLE>
It could be, I am just going to have to wait until I change my timing belt to try to figure out the problem.
Old Apr 12, 2005 | 03:26 PM
LShatchie's Avatar
A common whining sound from the engine bay is from the altenator belt. Check to see if it is loose.
needanew1
Jan 25, 2007 11:25 AM
needanew1
Jan 23, 2007 04:59 PM
surlung
Jan 20, 2006 04:47 AM
osiris316
Apr 29, 2002 05:54 AM
