check endine light.. need help
Old Apr 11, 2005 | 06:34 PM
Trailz-EX's Avatar
Default check endine light.. need help
i have a D16y8 boosted vafc 2 walbro 255 dsm injectors 450cc aem pressure regulator. i keep geting a check light and cant get it to stop, its
p1106 malfunction. air fuel metering.. how do i get it stop?
Old Apr 11, 2005 | 07:04 PM
resol's Avatar
Default Re: check endine light.. need help (Trailz-EX)
check all your wiring to that.
Old Apr 11, 2005 | 07:20 PM
Trailz-EX's Avatar
Default Re: check endine light.. need help (resol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by resol &raquo;</TD></TR><TR><TD CLASS="quote">check all your wiring to that.</TD></TR></TABLE>
to which? vafc , injectors, if it wasnt for obd2 id just take the stupid light bulb out haha
Old Apr 12, 2005 | 08:04 AM
EE_Chris's Avatar
Jump the service check connector and post up what 'blink' code you get.
Not knowing what P1106 is, I'd put a $1 on it being Code 1 or 43.
So what's the code?
Old Apr 12, 2005 | 08:10 AM
VanHonda's Avatar
Default Re: check endine light.. need help (EE_Chris)
Code 45 maybe? System too lean/too rich. If so, I get that code using the same setup only a VAFC 1. A lot of people get it and its just somthing you have to live with running that setup. Just check the code every now and then to make sure it isn't anything new.
Craig
Old Apr 12, 2005 | 09:53 AM
BoOsTeD C1's Avatar
P1106 is BARO sensor circuit range/performance fault
Old Apr 12, 2005 | 10:02 AM
EE_Chris's Avatar
Default Re: (VTEC_pWrD_CiViC)
Well, that is more than likely the VAFC's fault. The MAP and Baro sensor are basically one in the same and so when you intially start you car, they should be spitting out near the same voltage.
But now you've got a VAFC altering the MAP output by what...35-40%.
You don't really have a problem.
Old Apr 12, 2005 | 10:03 AM
VanHonda's Avatar
Is that the same as code 13? If so, another problem due to the hack, but no big deal. Pretty much same as the other one.
Craig
Old Apr 12, 2005 | 10:08 AM
EE_Chris's Avatar
Default Re: (VanHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VanHonda &raquo;</TD></TR><TR><TD CLASS="quote">Is that the same as code 13?</TD></TR></TABLE>
Yep.
ek98
Dec 24, 2007 08:21 PM
sexyblack93lude
Oct 24, 2005 04:08 PM
tegon-gsr
Jul 25, 2003 08:26 AM
EGsixer
Apr 9, 2003 02:58 PM
