Long Block into 96 EX How hard to go SOHC to DOHC
Old Apr 10, 2005 | 05:42 PM
w's Avatar
w
Default Long Block into 96 EX How hard to go SOHC to DOHC
First off yes i did search and didnt fins this so i hope its not a repost
http://www.hmotorsonline.com/s...30021
This was $600, how much more will i most likely end up spending. What else will i need. My plan is to turbo it and other little stuff.
I want to be pushing 250-300hp at the wheels, am i best off to keep my current 1.6sohc vtec and turbo it or switch to the dohc?
Is this even legal?
Old Apr 10, 2005 | 05:48 PM
pdiggitydogg's Avatar
Not legal - engine needs to be same year or newer than chassis
Youd need to do a lot of wiring to make the obd's match up (stick with same obd as your car)
You'll also need a transmission
Clearly, you didnt search very hard
Old Apr 10, 2005 | 05:50 PM
tur3oDC4's Avatar
Default Re: Long Block into 96 EX How hard to go SOHC to DOHC (hondadude96)
hmmm, you need to search again.
Old Apr 10, 2005 | 06:27 PM
.BigSexy's Avatar
most hood white kid
if you wanna go DOHC, just buy a complete swap. It will probably be cheaper, and easier to deal with because u wont have to deal with finding misc. parts. but if you want to be an SOHC soldier, then build the bottom end, and boost it
Live~Civic
Dec 28, 2010 08:05 PM
w
20
Apr 12, 2005 09:39 PM
New Dimensions
Mar 28, 2005 09:54 AM
Toecrumb420
Apr 28, 2004 03:48 PM
Mikey361
Apr 4, 2004 10:43 PM
