Depinning Ecu Wires
Ok I've run into a problem during my ls swap. I can't depin the ecu plug. Is there some sorta trick to it. I've been at it for like 2 hrs. I get mad, leave it alone and come back, and still the same results, Nada.
I have the eye glass screw driver and I've tried pushing the pin out, but it just doesn't work.
If you have any pictures that would be awesome also, because pictures just make it that much easier for me.
TIA
TIA
I'm lost now. When I used the screw driver I would push thru the small rectangular hole on the ecu plug, but now that your saying use a safety pin would I push the wire thru the smaller circular hole? Which hole am I suppose to push the wire out off?
Sweet....That helped out alot. I'm gonna try that tomorrow. Hopefully it will work because I'm not trying to destroy my plug. Thanks again for the picture.
Loaded Butane
Feb 23, 2002 05:08 PM
