two gas tanks
Old Apr 9, 2005 | 09:44 PM
zacdaddy77's Avatar
Default two gas tanks
ok I working on building a 10 second street del sol ( sleeved b18c1 turbo) my question is could I put a small 5 - 10 gallon fuel cell in the trunk and have a switch in the car to switch gas tanks ( I was thinking a switch from a dual tanked truck might work ) the reason I wanna do this is so I could be driving around on 10 psi and 93 octane and If I wanna turn up the boost I could just switch to the tank of race fuel
please let me know if this has been done or is doable
,Zac
Old Apr 9, 2005 | 11:11 PM
zacdaddy77's Avatar
Default Re: two gas tanks (zacdaddy77)
I'll check this in the morning
Old Apr 10, 2005 | 01:41 AM
Redline130's Avatar
It's been done, so it's definitely doable.
Old Apr 10, 2005 | 04:14 AM
NJIN BUILDR's Avatar
Default Re: two gas tanks (Redline130)
Many trucks and vans have duel tanks.You could use the switching hardware out of one of those.
Glenn
Old Apr 10, 2005 | 07:49 AM
Phase Change Racing's Avatar
Absolutely. The only difficult part for you will be that you need to also run a switching device on your fuel return line so you don't pump all your good fuel into your pump gas tank hehe. I often do a similar with street nitrous setups by running a single 1 gal fuel cell and dedicated fuel pump for the nitrous system.
Old Apr 10, 2005 | 11:32 AM
zacdaddy77's Avatar
Default Re: two gas tanks (Phase Change Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">Absolutely. The only difficult part for you will be that you need to also run a switching device on your fuel return line so you don't pump all your good fuel into your pump gas tank hehe. I often do a similar with street nitrous setups by running a single 1 gal fuel cell and dedicated fuel pump for the nitrous system.</TD></TR></TABLE>
ahhhhhh hell yea good thinking
Old Apr 10, 2005 | 03:46 PM
HT Chaplain's Avatar
Loved
what a great idea!
Old Apr 21, 2005 | 04:09 PM
dfoxengr's Avatar
manual valve and T off the return. electric switch for off and on for each fuel pump. only bad thing about the simple setup would be that you have to open the hood to switch the return
Old Apr 21, 2005 | 04:50 PM
With the seperate tank and pump you don't even have to dick with any switching equipment. The only hard part with you import boys is it can be a bit tricky to find a spot to stick a 1gal fuel cell.
Old Apr 21, 2005 | 04:52 PM
dfoxengr's Avatar
Default Re: (Phase Change Racing)
behind the back seat of course. just make a good box and bolt it to the floor.
i wouldnt go in the spare tire well for 2 reasons.
Old Apr 21, 2005 | 09:14 PM
Yeah, I guess as long as you build a proper firewall around the cell that would work just fine. Give me till fall and you guys won't need to worry about it, just another pair of bottle brackets and another bottle. Propane Rules!
prj
Jul 9, 2012 08:00 PM
fremontcivic
Jan 15, 2011 05:05 AM
Boosted_B_Series
Sep 22, 2008 02:19 PM
djicon2000si
Dec 16, 2007 11:07 AM
