Clamping a piston down to a lathe/milling machine?
Old Apr 9, 2005 | 08:00 PM
mos's Avatar
mos
Default Clamping a piston down to a lathe/milling machine?
I want to shorten the compression height, and machine some valve pockets into a piston, and I can't figure out a good way to clamp the damn thing down without damaging it. Anybody done this before?
Background: I'm a low budget guy so I'm not going out to buy an expensive fixture. The OEM replacements are discontinued from Yamaha... its old.
Would I be able to modify a regular piston ring clamp to work out?
Old Apr 11, 2005 | 10:19 AM
mos's Avatar
mos
Default Re: Clamping a piston down to a lathe/milling machine? (mos)
Ok, so I guess I'm going to glue some sandpaper down to a sheet of glass. Watch some TV while I slo o o o owly grind down the compression height of this thing.
Old Apr 11, 2005 | 11:38 AM
.RTErnie's Avatar
well...make a block of aluming, and machine a hole in it so the piston fits in it snug...like .010 clearance I guess...maybe less and then put a pin thru where the wrist pin goes to keep it from spinning and make sure it fits tight as hell. and then knock yourself out.
Note I'm not a machinist, but I did stay at a holiday inn last night.
Old Apr 11, 2005 | 11:57 AM
mos's Avatar
mos
Default Re: Clamping a piston down to a lathe/milling machine? (RTErnie)
I was thinking of trying something like that with wood. I picked up the piston for ten bucks, no way I'm going out to buy an expensive block of aluminum to do this...
Old Apr 11, 2005 | 12:08 PM
.RTErnie's Avatar
get a DA sander and go to down....and a die grinder while you're at it.
Old Apr 11, 2005 | 02:25 PM
4drsedaneg's Avatar
you should just be able to hold it in a milling vice on the flat sides, but get some plastic shim and use it between the jaws and the piston so you dont marr or deform it. then snug it up good and go to town. the piston should hold up fine, take light cuts if you are scared
Old Apr 12, 2005 | 03:23 AM
NJIN BUILDR's Avatar
Default Re: Clamping a piston down to a lathe/milling machine? (4drsedaneg)
http://www.bhjinc.com/1products/0-landing.htm
Click on piston tooling on the left.These are not cheap but it may give you some ideas.
Glenn
Old Apr 12, 2005 | 10:34 AM
mos's Avatar
mos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drsedaneg &raquo;</TD></TR><TR><TD CLASS="quote">you should just be able to hold it in a milling vice on the flat sides,
the piston should hold up fine, take light cuts if you are scared</TD></TR></TABLE>
I just clamped it right in the lathe ghetto style. No shims. Spun it up, cut the skirt down, and then cut a few mm off of the dished top. Barely scratched it any. I sanded the scratches down and it looks like it will work out fine.
I'm going to do the valve reliefs by hand. They are 90 degrees from the old ones I cut off...
Thanks for the replies.
lilo_goki
Feb 18, 2009 01:56 AM
DC4_MADMAN
10
Aug 23, 2006 08:52 AM
vinuneuro
Jul 30, 2005 10:51 PM
Seraph0
Jan 10, 2004 05:40 PM
