fuse keeps blowing
Old Apr 9, 2005 | 06:53 PM
GReddy212's Avatar
Default fuse keeps blowing
The fuse for my interior lights keeps blowing. I have no clue why. anyone have any ideas
Old Apr 9, 2005 | 10:04 PM
lv6l's Avatar
what interior lights are you talking about, the dome lights? or the intrumental lights?
Old Apr 9, 2005 | 10:20 PM
SuShiBoiiii's Avatar
Default Re: fuse keeps blowing (GReddy212)
just get a stonger fuse
Old Apr 9, 2005 | 10:33 PM
yellowdcn's Avatar
Default Re: fuse keeps blowing (SuShiBoiiii)
maybe an exposed wire somewhere? Have u been workign with car wires?
Old Apr 9, 2005 | 11:39 PM
sumptimwong's Avatar
DO NOT use a "stronger" fuse!!!!!!!!!!!!
this will not give your appliances the protection they need, and will also increase the risk of electril fire. ALWAYS ALWAYS ALWAYS use ONLY the recommended fuses for your car. however, u can safely move DOWN for the fuse rating, but you may have to replace it more often is all.
how long does the fuse last before it blows? does it go right away? are you sure you're using the correct fuse? make sure everything is OFF before u plug in the fuse. gl
Old Apr 10, 2005 | 04:15 AM
SearchBeforeUPost!'s Avatar
Default Re: fuse keeps blowing (sumptimwong)
You have a short in that circuit.
Old Apr 10, 2005 | 04:16 AM
someone else's Avatar
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">just get a stonger fuse</TD></TR></TABLE>
That is the kind of advice that catches someones car on fire.
Old Apr 10, 2005 | 04:27 AM
deserthonda's Avatar
wow i cannot believe that someone gave you an advice to put a bigger fuse i don't want him working on anyones car..like someone said you have a short in the system the problem is that fuse is for a few more things than just interior lites , you need to look into an electrical manual to see what that fuse runs and than start eliminating circuits to locate the short
Old Apr 12, 2005 | 10:56 AM
Creative911's Avatar
Default Re: (deserthonda)
Same thing is happen to my car, but the ecu fuse also blows.... turns out now I need a new wiring harness... anyone know where I can get one from?
tdubbebawllin
Jul 29, 2008 01:34 PM
vinuneuro
Mar 5, 2006 08:20 PM
BigIslandBoi
Aug 10, 2004 11:41 AM
Si_Power
Jun 23, 2003 08:12 AM
2camsaam
Mar 12, 2003 03:55 AM
