Base timing for d6y8
Old Apr 9, 2005 | 06:04 PM
Civicman86's Avatar
Default Base timing for d6y8
I knwo the timing stock is 12* on the crank marks. So does this mean I set the top left most cell to 12* also (in uber in my case).
Old Apr 9, 2005 | 06:17 PM
mtber's Avatar
Base timing is 16.50 deg.
Set your complete lowcam map to 16.50 deg and save it to a temp bin. Burn the file & run the car on it. Shoot your timing to 16.5 deg (red line on crank pulley)
Then return to your normal bin file for tuning :-)
Old Apr 9, 2005 | 06:20 PM
dustin's Avatar
Default Re: (mtber)
base timing for d16y8 is 12 deg. I'm not sure how you set base advance in uberdata. In hondata you set it in the config.
You don't need to burn any maps or anything to set base timing. Just jump the service connector and the ECU won't add any advance past the mechanical dist advance. Sync to the red line (12deg) and you're set.
Old Apr 9, 2005 | 06:24 PM
Civicman86's Avatar
Default Re: (dustin)
ok prob is you have to advance the dizzy to get only 11* and I guess i need to make the idle (top left colum) 13* to comensate for that one degree you cant get on the dizzy.
Reasy the dizzy wont work b/c obdI ecu with OBDII dizzy.
I set the top most column at 13.50 hope that works :-\
Modified by Civicman86 at 10:58 PM 4/9/2005
Old Apr 9, 2005 | 06:26 PM
dustin's Avatar
Default Re: (Civicman86)
I'd get an obd1 dist....
JDM97R
Sep 14, 2012 06:47 AM
raverx3m
Apr 9, 2012 09:15 AM
grant97teg
Nov 5, 2010 03:38 PM
1990si
Aug 7, 2006 12:34 PM
dubnine
Sep 16, 2002 01:35 PM
