Hondata s200 (extreme newbie)
Old Apr 9, 2005 | 04:43 PM
rafael_dias's Avatar
Default Hondata s200 (extreme newbie)
Hi guys,
I a complete nutter when it comes to tuning. I recently installed my full Spoon exhaust system and custom CAI. I was told to tune it. I started to do some research and heard that Apexi V-afc was a good start. But the price is a little high for it's performance. People are telling me to go for Hondata as it is a little more expensive but has more power..
The thing is I am unaware of the whole OBD1, OBD2 thing. I have a RHD JDM EK Si-R from Japan with a b16a. I think it is OBD2? and I need to convert back to OBD1? - https://honda-tech.com/zero...age=1 - I think this guy sells OBD2 adapters?
Anyway could someone clarfiy that for me? pleassse??
Just one more question, will I benefit much from the Hondata s200? I am not planning to do much to my engine at the moment, maybe some internal work but that will not happen till the end of the year - next year.
Leave me some comments or ideas..
Thanks for reading this!!
Old Apr 9, 2005 | 05:47 PM
Lord Helmet's Avatar
Default Re: Hondata s200 (Bunda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunda &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys,
Thanks for reading this!! </TD></TR></TABLE>
1. yes your car is OBD2
2. yes there are adapters for OBD2 to OBD1
3. Hondata s200 won't give you God like power since all you have is a CAI & Exhaust. At most it will do is remove the speed governor, smoothes out the dips through out the power band(That's if the tuner knows what he is doing on the dyno)
My analysis: Don't waste your money on the s200 if you only have a exhaust and cai. Unless you have a high compression all motor setup or boosted setup, don't waste you money just yet.
Old Apr 9, 2005 | 07:39 PM
Thanks for your opinion.
Money is not particularly a factor here, I mean under a certain price I will go to. But I just do not want to do things twice. I'd rather spend money and have it done properly.
Im not looking for huge amounts of power, just a little more.
How much are those adapters?
Old Apr 9, 2005 | 10:45 PM
PrettyLude's Avatar
those adapters vary from 70-150 dependin on where you get it from.
check out the sponsors section, they have good deals on adapters
Old Apr 9, 2005 | 11:43 PM
is the OBD2 -&gt; OBD1 harness all that i require to make the s200 work properly or is there more?
Old Apr 10, 2005 | 04:10 AM
NJIN BUILDR's Avatar
Default Re: (Bunda)
http://www.hondata.com/s200.html
You will also need a obd1 vtec ecu that has been modified for hondata.
Glenn
Old Apr 10, 2005 | 10:51 PM
^P28,P30,P72,P61,P08J,P30J,P72J OBD1 ecu's will work right?
do the ecu's need to be chipped or anything? or is it just a simple plug in play
Modified by Bunda at 12:13 AM 4/11/2005
Old Apr 10, 2005 | 11:14 PM
PrettyLude's Avatar
it needs to be socketed
Old Apr 11, 2005 | 12:30 AM
^ just socketed, is that all?
00FBPEM1
Engine Management and Tuning
Aug 13, 2015 10:01 PM
01_ITR
Jul 8, 2008 04:40 PM
tlcivic
Oct 25, 2007 06:00 AM
VtecAdvantage
Jan 5, 2006 06:36 PM
greddyturboGSR
Dec 19, 2002 02:41 PM
