Used a head gasket for 30min. and disassembled- Do I really need a new one???
Old Apr 9, 2005 | 04:33 PM
rfactor's Avatar
Default Used a head gasket for 30min. and disassembled- Do I really need a new one???
I just replaced what was a B16 PR3-2 head with a B16 PR3-4 Head.
Got it all together, and as absolutly ignorant as this sounds, was dismayed to find oil coming out the rear right corner (in relation to car). Turns out, head gasket went on upside down, shameful as it may be . Anyway, took it all off, and now I need to know how absolutly important it is to buy a new headgasket when I had one on that never even got hot. I really appreciate the help from the position of my lame-brained little mistake. Other than that, I also noticed a cap in one of the holes on my old head near where the leak occured (by the head bolt), this was on the PR3-2 head, but not on the PR3-4 head that leaked. I have pictures. Should I also cap my new head with this plug? (By the way, its going on a b18c1 block) Thanks!
JustW
Old Apr 9, 2005 | 05:39 PM
Lord Helmet's Avatar
Default Re: Used a head gasket for 30min. and disassembled- Do I really need a new one??? (rfactor)
When in doubt replace it anyways. In my case I would've reuse it since it didn't stay on the engine long enough to be properly broken in.
Old Apr 9, 2005 | 06:17 PM
vangc6780's Avatar
Default Re: Used a head gasket for 30min. and disassembled- Do I really need a new one??? (sleeperciv)
if it was torque down then i would throw that headgasket away!!!
its a bad ideal to use it once its torque down.... speaking from experience
Old Apr 9, 2005 | 06:28 PM
Default Re: Used a head gasket for 30min. and disassembled- Do I really need a new one??? (vangc6780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vangc6780 &raquo;</TD></TR><TR><TD CLASS="quote">if it was torque down then i would throw that headgasket away!!!
its a bad ideal to use it once its torque down.... speaking from experience </TD></TR></TABLE>
That's true but I've reuse a new headgasket that was torqued down and it ran 100K miles without any issues.
Old Apr 9, 2005 | 07:33 PM
non-VTEC's Avatar
i would buy a new one.........but if your to cheap to buy a new one then clean up the gasket as best you can and give it a coat of copper spray gasket sealer and re-use it.
Old Apr 13, 2005 | 09:16 PM
civicgsr209's Avatar
Its always a good idea to spend the time now to replace it since you already have the motor apart. Once the gsket has been crushed, its not designed to seal the same way a second time. I would spend the 60 bucks and get a new one.
Old Apr 14, 2005 | 01:45 AM
Green Lude 93's Avatar
im sure if the same head and block were used, it should seal up the same if neither were milled. but some time and future labor's sake, i would just spend the extra 60 for a gasket for peace at mind.
Old Apr 14, 2005 | 07:50 AM
95lstegman's Avatar
Default Re: (Green Lude 93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">When in doubt replace it anyways. In my case I would've reuse it since it didn't stay on the engine long enough to be properly broken in. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i would buy a new one.........but if your to cheap to buy a new one then clean up the gasket as best you can and give it a coat of copper spray gasket sealer and re-use it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr209 &raquo;</TD></TR><TR><TD CLASS="quote">Its always a good idea to spend the time now to replace it since you already have the motor apart. Once the gsket has been crushed, its not designed to seal the same way a second time. I would spend the 60 bucks and get a new one.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green Lude 93 &raquo;</TD></TR><TR><TD CLASS="quote">but some time and future labor's sake, i would just spend the extra 60 for a gasket for peace at mind.</TD></TR></TABLE>
need i say more? listen to all this advice. nobody yet has said it's a good idea.
Old Apr 14, 2005 | 01:40 PM
Antilag's Avatar
Default Re: (95lstegman)
yeah especially if it was not only torqed down but installed upside down. save the hassle and spend the 60 bucks for a new one.
Old Apr 26, 2005 | 11:35 AM
rfactor's Avatar
For the record, I went most definently went with a new one, didn't cut corners anywhere else, so It'd been stupid to there. Got a good one, thanks for the input!
Old Apr 26, 2005 | 03:27 PM
Antilag's Avatar
Default Re: (rfactor)
strike1545
May 24, 2010 10:42 AM
SlowPokeEg
Mar 22, 2008 09:10 PM
DC2SIR-G
Oct 17, 2005 01:54 PM
fiftee_su
Oct 8, 2003 09:23 PM
InfamousRS
May 1, 2002 02:15 PM
