New set up Idling at 3500RPM.. map sensor problem??
Well I finished the install of my new motor...
Basically I took the complete motor set up from a 95 civic SI and put it in my Type R.....
The only part I changed was ... I took off a spoon throttle body and put on a bigger 70MM BBK throttle body..
besides that there is nothing different,, used the AEM EMS from the civic with a jumper harness...
When i started the car everything was fine except that its idling at 2500RPM..
Then i unplued the vacum to the map sensor and now the car idles fine(900RPM)
If i put the vacum line back on the 3 bar map sensor it idles at 2500RPM again..
so I guess its either something electronic that has to do with the map sensor but i know the map sensor itself is ok since i tryed 2 different ones,,,
Could it be something with the EMS that reading a bigger Throttle body??
I dont think its a vacum leak since i didnt find any..
also the throttle bodys are slightly different,, the spoon one that was originally on is for an b16a2..and the BBK is for a b18b... so there the iddle air controle valve under the throttle body on the BBK but not on the spoon!!
would that matter??
PLEASE HELP!
Tyler
would that matter??
PLEASE HELP!
Tyler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">AEM ems has idle adjustments.. Use them.</TD></TR></TABLE>
adjust the idle from the ems software and be done with it.
comptechgsr2000
May 8, 2002 03:53 PM
