turbo lubrication (inlet and outlet questions)
Old Apr 9, 2005 | 03:21 PM
RACEPAK's Avatar
Default turbo lubrication (inlet and outlet questions)
hello everybody
i have a dumb question for ya'.
my turbo's middle (oil) section is upside down so the return flange is up.
so can i feed the turbo from the return and return fom the feed? or should i clock the turbo?
best regards moshik galimidi
Old Apr 9, 2005 | 03:22 PM
kevino002's Avatar
Default Re: turbo lubrication (RACEPAK)
Just clock the turbo, do not run it the way you are talking about...!!!
Old Apr 9, 2005 | 03:32 PM
Evanmb44's Avatar
Default Re: turbo lubrication (kevino002)
do not even think about running it the way you said. the lines are different sizes and the return must be bigger than the feed, otherwise you will blow your seals in no time. just clock the turbo...its easy to do
RACEPAK's Avatar
i'm asking this because i saw some projects that the flange of the oil is upwrds.
could it be thats some turbos have flange also on the inlet?
Old Apr 9, 2005 | 03:33 PM
oxSLEEPERxo's Avatar
yea you need to clock the center of the turbo
Old Apr 9, 2005 | 03:42 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">i'm asking this because i saw some projects that the flange of the oil is upwrds.
could it be thats some turbos have flange also on the inlet?</TD></TR></TABLE>
some turbos inlet look like the outlet, but they arent, they hvae a tapped tread to screw in fittins
Old Apr 9, 2005 | 07:31 PM
trentepic's Avatar
Default Re: turbo lubrication (USDM 4G VTEC)
oem mr2 turbo 92 model from japan ne ways prob us also have inlet and drain on the same flange. bottom, they got it all done special i guess, so unles u got one of those.
hangac1093
Oct 27, 2006 06:23 PM
KURUPTinc
Aug 20, 2005 09:54 PM
herde1724
Jul 21, 2004 06:53 PM
Ri5e
Jan 3, 2002 03:48 PM
