Shifter problems (Automatic)
Hello everybody. I recently purchased a 1990 4 dr. LX. The car came without an ECU. I purchased a pm5 for it, but I wasnt sure if it was for a manual or auto. I hooked it up, car runs and shifts fine, except that it is locked in Park. I have to use the key in the shift unlock socket to select gears. Do you think it could be the wrong ecu, or something unplugged???? Thanks in advance guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda »</TD></TR><TR><TD CLASS="quote">you might also tell them thqt this is a theft recovery and the damage could have occured by the thief ....</TD></TR></TABLE>
WERD ^ what he said
WERD ^ what he said
if u cant find problem... its not to hard to byepass the lockout system... just remove the console and u can plainly see what locks it in park when u push key in slot.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CUSTOMCONNECTION »</TD></TR><TR><TD CLASS="quote">if u cant find problem... its not to hard to byepass the lockout system... just remove the console and u can plainly see what locks it in park when u push key in slot.....</TD></TR></TABLE>
yeah i know that is a option but brandon isnt the type to do that he would rather just fix it the right way ... gotta give him a
for being that way
for being that way
for being that way </TD></TR></TABLE>
WERD. Thanks Ralphie
for being that way </TD></TR></TABLE>WERD. Thanks Ralphie
Needs to be About 20% Cooler
u have a manual ECU for a auto. it will run the car fine but 2 things will not work.
#1 is the locked in park. to fix easaly, on the lockup control box under the driver seat near the front center, theres a white\red wire. that goes to the ecu. i dont know if u ground it (most likly) or suplly 12 to get the "when brake depresed u can shift out of park".
#2 is the AT lock-up sol. or "5th gear" as i have heard it called. i have a light hooked up to mine and can tell u this: it only works >25 MPH, only when the trany is in 3rd or 4th gear, and only comes on if ur on the gas; I.E. if u take ur foot off on the highway it will go off, u need to apply some presure to keep it locked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brandon H »</TD></TR><TR><TD CLASS="quote">Yep. As soon as I turned the ignition switch to ON, it flashed one time. What does that mean???</TD></TR></TABLE>
if it flashed one time and not again thats normal. if it repeated one flash bout once every second then u got a code 1 or O2 sensor.
Well, I fixed the problem guys. It was a manual ECU. Went to the Wrecking Yard today and picked up an auto one. BUT, now its throwing a code 12, I guess its the battery. Gonna pick up a new one tomorrow. Thanks again fellas!!!
