TDC sensor
Old Apr 9, 2005 | 09:47 AM
txq45's Avatar
Default TDC sensor
Ok, jsut finished installing swap D15 vtec in 89 civic SI..Trying to turn engine over and there is no engagement of the starter.. Looked at ECU and get 8 flashes then a pause then 8 more.. I'm assuming the TDC sensor is disconnected ? but where is it ? ..
I did have to rewire the distributor for the new engine (old one had barrel connectors and new one had the gray rectangle ones ..7 wires on each distributor but the old one had two white wires ..
I'm thinking that's it and I have them crossed..
Thanks N aDvance
Old Apr 9, 2005 | 11:01 PM
PrettyLude's Avatar
check ur wiring again, the tdc sensor is in the dizzy, try swapping it out with another dizzy and see if the problem goes away
Yuta
Oct 13, 2018 08:07 AM
Syke909
Nov 26, 2013 03:14 AM
Unphzd
Dec 13, 2010 11:30 PM
