oil pressure
Old Apr 8, 2005 | 09:27 PM
braypunt's Avatar
Default oil pressure
what are causes of low oil pressure and what can happen if your oil pressure is low?
I believe mine is on the low side... should i worry? this is a stock 96 civic dx.
what is the minimum oil psi it should be at?
Old Apr 8, 2005 | 09:43 PM
_Cyclone_'s Avatar
Default Re: oil pressure (braypunt)
You say you have low oil pressure... what are you comparing it to? Give numbers and some details about your setup.
Old Apr 9, 2005 | 12:01 AM
s2kdre's Avatar
Default Re: oil pressure (CycloneBlue_1.6EL)
at idle hot motor at 15psi
Old Apr 9, 2005 | 12:04 AM
braypunt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">You say you have low oil pressure... what are you comparing it to? Give numbers and some details about your setup.</TD></TR></TABLE>
It's just a stock motor. My friend gave me an oil pressure gauge he had that he was gonna throw out (an el cheapo one) so I just put it on so I could monitor the health of my motor. It's reading around 5-10psi at idle after the car is warmed up
trulyshavedintegra
Dec 9, 2012 05:06 AM
dragvixen
Jul 10, 2009 11:20 AM
on2wheels
Jan 25, 2008 06:39 PM
platinum00
May 14, 2006 06:40 AM
fanta!
Aug 11, 2005 02:34 PM
