b16a timing belt
Old Apr 8, 2005 | 02:33 PM
mdiym13's Avatar
Default b16a timing belt
I replaced the water pump and timing belt on my b16. I started the car and it ran like crap. I took it apart made sure cam arrows were pointing up and that the crank pulley arrow was ligned up. Put it back together and it ran worse. What could be the problem ?? Any help would be greatly appreciated.
Old Apr 8, 2005 | 08:29 PM
Kendall's Avatar
Double check the timing. It's particularly easy to screw up if you haven't done many timing belt jobs.
Old Apr 11, 2005 | 03:43 AM
JimBlake's Avatar
Default Re: b16a timing belt (mdiym13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdiym13 &raquo;</TD></TR><TR><TD CLASS="quote">... made sure cam arrows were pointing up...</TD></TR></TABLE>Remember those arrows are only approximate. The REAL timing marks are little dimples out at the teeth of the camshaft sprockets. They line up horizontally. Lay a straightedge across the camshaft centers & line up with that.
Old Apr 11, 2005 | 07:27 PM
PupaScoopa's Avatar
Default Re: b16a timing belt (JimBlake)
Those dimples line up ASSUMING that you've already lined up the crank at cyl. 1 TDC. If your cam gears are lined up and it's still running like crap, both cams may be off in relation to the crank.
flipldls
Jun 6, 2010 08:45 PM
ezza
Jan 25, 2010 12:10 PM
eg6d15
Jan 7, 2008 01:21 PM
90jdmcrxdude
May 17, 2006 09:39 AM
NewRacer
May 13, 2003 07:58 PM
