Building an a6, what kind of pistons and rods
Old Apr 8, 2005 | 09:03 AM
c1civic's Avatar
Default Building an a6, what kind of pistons and rods
can i use any d series rods or pistons, or do i have to get some specifically for the d16a6
thanks
David
Old Apr 8, 2005 | 09:25 AM
busychild's Avatar
Default Re: Building an a6, what kind of pistons and rods (c1civic)
what plans do you have for the motor? FI, All Motor, Nitrous?
I wanted to gain some compression in my a6 and went with the p29 pistons and stock rods. I added in the ARP rod bolts for good measure.
Old Apr 8, 2005 | 10:02 AM
c1civic's Avatar
building for boost
Old Apr 8, 2005 | 10:35 AM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: (c1civic)
if i were you i would get s ome Scat rods for your A6 . the cost about 280 shipped. find a good deal on some pistons ( low comp ) and you should be OK for like 10-15 PSI. Enginemanagement will be key so dont cheap out and get an FMU, instead runTurbo edit and you should be golden. for that you will need a PR4 or 90-91 PM6 ECU to chip. read here for lots of info on how to do it all on your own http://www.homemadeturbo.com
good luck!
Old Apr 8, 2005 | 10:37 AM
c1civic's Avatar
the thinkgim stuck on is the fact that i want to put this in a 97 civic obd2, what ecu
Old Apr 8, 2005 | 10:41 AM
EP3_05's Avatar
Default Re: (julio_bOostamante)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante &raquo;</TD></TR><TR><TD CLASS="quote">if i were you i would get s ome Scat rods for your A6 . the cost about 280 shipped. find a good deal on some pistons ( low comp ) and you should be OK for like 10-15 PSI. Enginemanagement will be key so dont cheap out and get an FMU, instead runTurbo edit and you should be golden. for that you will need a PR4 or 90-91 PM6 ECU to chip. read here for lots of info on how to do it all on your own http://www.homemadeturbo.com
good luck!</TD></TR></TABLE>
Just remember for an aftermarket dseries rod(besides eagle) you will need to notch the block for the rods to clear the bottoms of the cylinder walls.
EDIT: the new style eagle rods do not require notching but the older eagle rods do require notching
I'm a Jackass
Since you are OBD2 your gonna need to convert to OBD1 ( its more user friendly and more info is out there for stand alone systems) SO if your gonna run OBD1 then i suggest using http://www.UBerdata.org
your using what head with this block?
Old Apr 8, 2005 | 10:43 AM
I'm a Jackass
Default Re: (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">the thinkgim stuck on is the fact that i want to put this in a 97 civic obd2, what ecu</TD></TR></TABLE>
yeah, good point. there is alot of info on the old one for building D series motors check em ou t
http://www.theoldone.com/
Old Apr 8, 2005 | 11:38 AM
c1civic's Avatar
im also planning on using the a6, this is going ot be my daily
willyb92
19
Jun 4, 2010 06:27 PM
d16dcoe45
Sep 27, 2006 05:15 PM
allmotor99lude
Jan 4, 2006 11:37 AM
jdmcivic1999
May 30, 2005 09:50 PM
Slimm-rw-
May 3, 2004 01:06 PM
