what should my expectations be w/ a port & polished TB ?
im thinking of getting my throttle body bore, port, and polished . i have a sirII throtle body . its 60mm. stock . it would be 64mm. after the bore, port, and polished !
what type of performance increase should i expect ? is it goin to be noticiable ? i just want to know if its worth the money to go out and get this done . thanks in advance
edit: my mods are : aem intake, comptech header, cat back exhaust, test pipe
skunk2 intake manifold, b&m fuel pressure regulator, aem cam gears, ground kit im running a ITR ecu along with a APEXi VAFC .
Modified by red_ek_hatch at 1:36 AM 4/8/2005
i doubt you would get anything, maybe loose hp, Get some cams... or go turbo, then work on maxing out your airflow
Guru Designs
Dec 31, 2005 07:55 AM
red_ek_hatch
16
Apr 8, 2005 04:01 PM
red_ek_hatch
Apr 8, 2005 04:26 AM
jonnybravo
Sep 18, 2002 08:00 PM
