what causes rings to spin?
Old Apr 7, 2005 | 04:11 PM
b00stedbyFastrax's Avatar
Default what causes rings to spin?
had a problem of oil pushing out of the filter on my endyn can. decided to pull the pistons and found that both compression ring overlap each other. what can cause this?
Old Apr 7, 2005 | 10:22 PM
earl's Avatar
Default Re: what causes rings to spin? (b00stedbyFastrax)
Rings sometimes spin on there own. I doubt that is your problem, however.
Old Apr 8, 2005 | 12:45 AM
s2kdre's Avatar
Default Re: what causes rings to spin? (earl)
the ring compressor wasn't on right i guess when they put the pistons in.
Old Apr 8, 2005 | 03:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Rings sometimes spin on there own. I doubt that is your problem, however.</TD></TR></TABLE>
care to elaborate some more earl? would appreciate it.
Old Apr 8, 2005 | 03:16 AM
NJIN BUILDR's Avatar
The "ring gaps line up and I have no compression"is wrong and just doesn't make any sense.Pressure or vacuum doesn't need line of site to equalize.It will go around a corner nearly as fast as it will travel in a straight line.
Glenn
Old Apr 8, 2005 | 06:49 AM
earl's Avatar
Default Re: what causes rings to spin? (NJIN BUILDR)
What Glenn says is very true and somewhat negates all the stress on where you place your gaps at. Rings can move on the piston based on how round and how tapered your bore is, as well as the rpms you turn.
Old Apr 8, 2005 | 06:58 AM
dennis's Avatar
You *probably* did it when you installed them - depending on what kind of compressor you used, they're really easy to spin around. BTW, which kind did you use? I orginally used the cheap one you tighten with an allen wrench and ended up getting my number 1 rings inline - blowing oil out of #1.
Finally pulled the piston and bought/used a much better ratcheting scissor type ring compressor. No problems since.
Old Apr 8, 2005 | 08:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">What Glenn says is very true and somewhat negates all the stress on where you place your gaps at. Rings can move on the piston based on how round and how tapered your bore is, as well as the rpms you turn. </TD></TR></TABLE>
thanks for clearing that up, guys. btw, used to pull 8800 and no prbslem and then went up to 9400 then it happened.
pornstar4777
Feb 14, 2008 12:47 PM
Trailz-EX
Dec 1, 2004 07:50 PM
EKB18BPR3
Jul 10, 2004 04:17 PM
DirtySoda
Oct 13, 2003 08:10 PM
b20ek
Jun 6, 2003 06:14 AM
