what should i expect from port and polished TB ?
Old Apr 7, 2005 | 11:51 PM
red_ek_hatch's Avatar
Default what should i expect from port and polished TB ?
im thinking of getting my throttle body bore, port, and polished . i have a sirII throtle body . its 60mm. stock . it would be 64mm. after the bore, port, and polished !
what type of performance increase should i expect ? is it goin to be noticiable ? i just want to know if its worth the money to go out and get this done . thanks in advance
edit: my mods are : aem intake, comptech header, cat back exhaust, test pipe
skunk2 intake manifold, b&m fuel pressure regulator, aem cam gears, ground kit im running a ITR ecu along with a APEXi VAFC .
Modified by red_ek_hatch at 1:31 AM 4/8/2005
Modified by red_ek_hatch at 1:32 AM 4/8/2005
Old Apr 7, 2005 | 11:59 PM
Micro's Avatar
Default Re: what should i expect from port and polished TB ? (red_ek_hatch)
It wouldn't be 'Ported and Polished' .... only cylinder heads get that work. You're throttle body will be 'Bored to 64mm and Tapered to 68mm'.
You can only expect as much gains as your other modifications. If you have a stock motor, you will barely feel anything. zIf you already have an intake manifold, GOOD header and maybe some cams... you'll DEFNITELY feel a difference.
Old Apr 8, 2005 | 12:33 AM
Default Re: what should i expect from port and polished TB ? (Micro)
skunk2 intake manifold, b&m fuel pressure regulator, aem cam gears, ground kit im running a ITR ecu along with a APEXi VAFC . should it be noticiablr with what i have ?
Old Apr 8, 2005 | 04:26 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_ek_hatch &raquo;</TD></TR><TR><TD CLASS="quote"> my mods are : aem intake, comptech header, cat back exhaust, test pipe
skunk2 intake manifold, b&m fuel pressure regulator, aem cam gears, ground kit im running a ITR ecu along with a APEXi VAFC . should it be noticiablr with what i have ?</TD></TR></TABLE>
I'm doubting it. You also have to consider the fact that different engines with different mods will not always react the same to any additional mods.
wasanissanFL
11
Feb 19, 2015 11:08 AM
snowskater34
Apr 16, 2010 07:44 PM
red_ek_hatch
16
Apr 8, 2005 04:01 PM
red_ek_hatch
Apr 8, 2005 07:01 AM
93jdmr
Jan 19, 2004 11:58 AM
