timing belt problem
Old Apr 7, 2005 | 10:47 PM
only4cylinders's Avatar
Default timing belt problem
ok i gots a brand new motor (b20b with LS head) with crower turbo cams and a Vtec water pump 22 teeth (was a LS but changed to see if that was the prob.) anyway everytime i tighten the timing belt and i rotate the crank to see how tight it is, it gets loose then tight but it rotates, like it gets loose between the cam gears then back cam gear and water pump then crank and front cam gear? im thinking the cams are off a little? but i dont know, cant anyone help?
thanx, Mike AKA 4cylinders
Old Apr 8, 2005 | 09:07 AM
delacampos's Avatar
Default Re: timing belt problem (only4cylinders)
what timing belt are you using?
Old Apr 8, 2005 | 12:18 PM
Default Re: timing belt problem (delacampos)
i used a LS belt wit the LS water pump, and a GSR belt with the vtec water pump still does to samething?
natecivic92
Feb 23, 2008 09:13 PM
Renegade
Feb 13, 2007 08:01 AM
Tony_EM1
Nov 10, 2005 08:17 PM
gsrvtechatch93
Jun 5, 2004 09:13 PM
JR Integra
May 3, 2004 04:17 PM
