more hp NA than turbo? wtf?
b20 vtec turbo 11.2-1 cr 4psi boost 187hp & 140 tq
na car ran 200hp & 145 tq
wtf?
only difference between na & turbo is the t3/t4 .57 trim turbo
all internal componets the same
help please!
wtf?
help please!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9341civic »</TD></TR><TR><TD CLASS="quote">b20 vtec turbo 11.2-1 cr 4psi boost 187hp & 140 tq
wtf?
help please!</TD></TR></TABLE>
I don't see how this is possible, unless the turbo car had zero timing in it, was running at a 9:1 AFR, no intercooler, and a 2" downpipe.
wtf?
wtf?
</TD></TR></TABLE>Whut....4psi of boost? Who the hell would boost that low wif a T3/T4 57 trim? And why would you slap a turbo on with that kind of compression ratio?! Sounds pointless to me.
wtf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">Whut....4psi of boost? Who the hell would boost that low wif a T3/T4 57 trim? And why would you slap a turbo on with that kind of compression ratio?! Sounds pointless to me.</TD></TR></TABLE>
yea but he still should have made more power. somethings not right.
too much overlap from the cams? CR is really high for a boost setup + everything the same = no change in tuning? then being that advanced for an n/a setup will mess you up when going turbo... danger!
i used the same tuner for both the na setup & the current turbo setup
i made less power on the dyno with the turbo setup @4psi
today i reinstalled the 7psi spring in the wastegate and it feels healthier
, but still needs to be tuned more
ems 1010 ver1.11
, but still needs to be tuned moreems 1010 ver1.11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian »</TD></TR><TR><TD CLASS="quote">that turbo doesnt even come alive till after 9-10psi.</TD></TR></TABLE>
da trooth
da trooth
Try retarding the in-boost timing. When the mixture gets thicker it takes longer for the flame to spread.
Also, you may be misfiring. You should be using plugs a step colder than before and gapped at 0.030" or so.
