Prelude antena going bad?
Old Jan 28, 2002 | 03:19 PM
Chris4x4gill2's Avatar
Default Prelude antena going bad?
The radio in my 96 Prelude is developing alott of static. It is not the speakers...They are all after market and pretty new. And I dont think it is the head unit(also new). I was told it could just be a bad ground on the anteena, can anyone tell me how to find the ground for the antena?
Old Jan 28, 2002 | 03:32 PM
CanadaCivicSIR's Avatar
New User
Default Re: Prelude antena going bad? (Chris4x4gill2)
The antenna ground is where it attaches to your vehicle, the base it gets screwed to is the ground. You might have to buy a new antenna if the wire connected to your antenna is cracked or pinched. A signal amplifier might be able to correct your problem.
Or the connection to your deck might be loose.
Old Jan 29, 2002 | 02:22 PM
Default Re: Prelude antena going bad? (CanadaCivicSIR)
You say that the grtound is where it screws into the base, so there isn't a ground wire? I tried one of those Signal Amplkifiers, but it only amplifies the staitc. I checked the connection at the headunit also it is tight. Can you tell me how to get to the mounting plate for the antena? I know you have to take out the trunk liner, but how does it come out? do you have to remove the jach from its holder?Any help would be appreciated.
[Modified by Chris4x4gill2, 11:22 PM 1/29/2002]
Old Jan 29, 2002 | 02:59 PM
New User
Once the trunk liner is off you can inspect the cables to see if it is damaged.
The antenna I believe is screwed on in the center.
Or it could be on like a civic and screwed on the sides.
If you are unsure take it to an audio install shop and have them take a look at it.
Old Jan 30, 2002 | 05:01 AM
Does the trunk liner just pop out? or is it held in by some screws or something?.....Also can anybody recommend a good manual for the 96 preludes?
Old Jan 30, 2002 | 05:08 PM
bob01721's Avatar
I don't know about your trunk liner, but most are held in with plastic fasteners that just pull right off.
Re good manual for your car, try http://helminc.com/helm/homepage.asp for the factory service manual.
Old Jan 30, 2002 | 06:24 PM
Default Re: Prelude antena going bad? (bob01721)
Thanks fro the information.
vinuneuro
Audio / Security / Video
Sep 11, 2007 11:29 AM
outlawstar27
May 13, 2007 09:17 AM
shimmycocopuffs
Oct 24, 2006 04:12 PM
pocza_h22
Aug 4, 2005 05:39 PM
