Need some technical help. (*Zzzzzip, Puts on flame suit*)
Old Apr 7, 2005 | 12:50 PM
Osokwik's Avatar
Default Need some technical help. (*Zzzzzip, Puts on flame suit*)
I'm finishing up the turbo project and have 2 more things to purchase. Before I begin, here's my current setup:
Car: 1999 Civic Si
Current bolt-on's:
- '00 ITR cams, IM (w/ Hondata gasket), TB, and valve springs
- Hondata S200 w/ 3 step
-ACT flywheel w/ Exedy stage 1
- ES mounts and Silver's engine damper(don't flame; works great)
- 3" header-back exhaust
- Oil temp, oil press., EGT, Boost, Fuel pressure and water temp. guages
-Moroso baffled oil pan w/ turbo return
-Walbro 255 pump
Current Turbo parts in waiting:
-Blox maniflod
-Tial 38mm WG w/ 90deg elbow
-Greddy BOV + turbo timer
Waiting to buy:
-Turbo
-Intercooler setup
- Quaife (not now though.... )
Getting to the point, I need to purchase a turbo and IC to complete this project. I know the manifold is for a T3 setup and because I haven't built the bottom end I'm only going to boost ~7-8psi. I need some insight as to what turbo will best suite my needs. I'm also not planning on draging this car. Mostly I want a good mid-high turbo setup for weekend driving (my car only has 27,XXX miles on it). I want to get this done before the end of May and need to know what turbo (Comp. .XX A/R and Turbine .XX A/R specs) I should be purchasing. It's all a little confusing to me. I also have to make sure it fits my manifold (Keeping A/C by the way )
Old Apr 7, 2005 | 01:02 PM
Ben Huynh's Avatar
Default Re: Need some technical help. (Osokwik)
This is a good option: http://www.importparts.com/sho...=5947
Old Apr 7, 2005 | 01:21 PM
JDMpianoguy's Avatar
a 57 trim turbine will fit you well with a nice .63 or so AR compressor housing to make some good high end still. It will spool quick and still have good pull on the top end. I liked my SC34 for that reason.
Old Apr 7, 2005 | 03:36 PM
Osokwik's Avatar
Default Re: (JDMpianoguy)
This is very helpful. So what would be a good Comp .XX a/r and Turbine .XX a/r turbo for this setup and goal?
Old Apr 7, 2005 | 04:07 PM
lanojp1's Avatar
ill recommend my own...garret t3/t04e 57 trim .63 ar
Old Apr 7, 2005 | 04:45 PM
like the above stated...57trim with .63 like his garret or my SC34 (which i am selling with only 5k miles on it)
Old Apr 7, 2005 | 04:50 PM
Benjithx's Avatar
your setup sounds good, but its missing one thing, (see sig)
Old Apr 7, 2005 | 06:29 PM
Osokwik's Avatar
Default Re: (Benjithx)
What do you think about ,say, a 57trim with a .48 or .55? Too small of a turbo?
Old Apr 7, 2005 | 06:49 PM
adseguy's Avatar
Default Re: (Osokwik)
no not to small, but with the higher rev of that motor it may die out alittle bit in the high end...still a solid choice though if you're not looking for big numbers
Old Apr 8, 2005 | 07:47 AM
Osokwik's Avatar
Default Re: (adseguy)
Would a .63 work well for that psi?(7-8psi)
Old Apr 8, 2005 | 07:54 AM
Muckman's Avatar
Moderator in Chief
Where in western NY are you?
Old Apr 8, 2005 | 08:14 AM
Osokwik's Avatar
Default Re: (Muckman)
Rochester, like yourself.
Old Apr 8, 2005 | 08:28 AM
Muckman's Avatar
Moderator in Chief
Sweet.
GT30 or GT28 would provide excellent spool and medium amount of power. Or if you want something cheaper SC34.
Old Apr 8, 2005 | 09:23 AM
Osokwik's Avatar
Give me an example as far as C .XX a/r and T .XX a/r are concerned.
for a Rochester H-T memember!
Old Apr 8, 2005 | 09:30 AM
dasher's Avatar
Default Re: Need some technical help. (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">This is a good option: http://www.importparts.com/sho...=5947</TD></TR></TABLE>
That looks nice ben and the price is also right .....
Can you choose a v band turbine housing instead of 5 bolt with that gt30R? How much does it run extra?
Old Apr 8, 2005 | 05:34 PM
Osokwik's Avatar
Default Re: Need some technical help. (dasher)
anyone els like to jump in?
Old Apr 8, 2005 | 09:12 PM
Blue98Ex's Avatar
GT28rs if u have the money
PaJeeZy
Mar 26, 2007 12:07 AM
projectPSI
Dec 5, 2004 12:12 PM
projectTeG
Jun 20, 2004 07:34 AM
EJ1_519
Mar 22, 2004 07:13 AM
AznPrideYo
Jan 28, 2004 09:54 AM
