94ex vtec ecu
Old Apr 6, 2005 | 10:48 AM
xwade01's Avatar
Default 94ex vtec ecu
Is it tru on the 94 ex vtec ecu u need to move 2 diff pins in order for it to run right on the 4th gen swap?? i read somthing like that on cb7.. if any1 knos for sure, could you help me out n tell me which 2 pins!?
thanks
Old Apr 6, 2005 | 11:44 AM
Intense3.2's Avatar
Default Re: 94ex vtec ecu (xwade01)
What swap are you talking about?
Old Apr 6, 2005 | 03:21 PM
raceACCORDingly's Avatar
yeah the 5th gens ecu are odd ***** you have to swap pins A6 and A11
Old Apr 7, 2005 | 06:02 AM
xwade01's Avatar
A6 an A11???? some guy told me q6 and a11... and he also said it was a orange n pink wire
so we did it last night.... and it started idling better and was a lil more responsive..
Old Apr 7, 2005 | 08:28 AM
sonlyte's Avatar
Default Re: (xwade01)
does the pin swap apply if you put a f22b in a 4th gen with 94 ex ecu? If so could it be causing my idle problems at low RPM?
Old Apr 8, 2005 | 02:30 PM
xwade01's Avatar
BUMP
i need to kno if the q6 and a11 was rite orange and pink? instead of a6 n a11
Old Apr 8, 2005 | 09:41 PM
http://board.hondasociety.com/...61998
a6 and a11
if you have a bumpy idle or o2 CEL and/or an EGR CEL its cuz of the pin swap.
Old Apr 8, 2005 | 11:19 PM
xwade01's Avatar
No... i dont have a bumpy idle anymore.. but the CEL is the map sensor code, whats up w/dat!?
Old Apr 10, 2005 | 05:08 PM
xwade01's Avatar
Yea.. well idno if its eexactly q6.. becuz we jus took the solid orange wire, and jumped it w/ the pink wire bcuz the guy said it was a orange and pink wire, so we jus did that..... but even at that it idles alot better... but now sumtimes i have these probs w/ my auto seatbelts, and my heat jus turns on... i think its becuz 1 of those wires, not really sure!!?!?
But i would like to kno if any1 has a pin out diagram for a 90 and a 94 ecu.. thanks
Old Apr 11, 2005 | 02:35 AM
pins are a,c, & d.
i assume the q is an a
Old Apr 11, 2005 | 08:39 AM
sonlyte's Avatar
Default Re: (raceACCORDingly)
how many pins in each accordingly a,c,d? Which is a conn?
bobbyboy545
Mar 19, 2024 12:43 PM
canospeed200
Jun 22, 2010 07:28 PM
spatula
Jul 19, 2005 01:25 PM
civic_rider
Feb 3, 2004 07:34 PM
