Do you 3'' will be overkill for my setup?
Getting ready to install my little ihi turbo on my d16 and want to know if yall think a 3" downpipe would be overkill? I want the downpipe that's going to spool it up the fastest but this turbo is so small I feel a 2.5 might be more reasonable." Let me know yall's opinion is. I want my setup to be similar to a supercharger setup, no lag. I am going to be using a pretty high flowing manifold. I will take pics when I get home. Nick
If you want it to spool as fast as possible theni would do 3" for sure. It might not make any difference over a 2 1/2" but then again if its worth doing its worth doing right. and if you did 2 1/2" you would always be asking yourself if it would be better if you had only gone with 3"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict »</TD></TR><TR><TD CLASS="quote">you should run 3in. that way it is already there if you decide to put some bigger power out later on. and it will help your turbo spool a little faster</TD></TR></TABLE>
i agree.
i agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict »</TD></TR><TR><TD CLASS="quote">you should run 3in. that way it is already there if you decide to put some bigger power out later on. and it will help your turbo spool a little faster</TD></TR></TABLE>true
