tranny oil flush help
Old Jan 28, 2002 | 07:12 AM
magic hat #9's Avatar
Default tranny oil flush help
well, the weatherman tells me it'll be almost 60deg here in ct tomorrow so i plan to change my tranny oil. i (unwisely) didn't get mtf from mr mike k, so i'll stop into the local acura dealer and pick up 3qts. i've read the helms manual and changing the oil looks easy enough, but they don't have a good picture of where the oil fill and drain plugs are. can someone please post pictures of where to drain, check the level, and fill the tranny oil? thanks!
Old Jan 28, 2002 | 07:21 AM
nEoMuGen's Avatar
Default Re: tranny oil flush help (monkey_truckR)
This color pictured site should help ya:
http://www.c-speedracing.com/howto/t...ransfluid.html
Lip's Avatar
Lip
there is a plug with a square on it. thats your fill. what to do is....drain the tranny first. then put that drain plug back in. undo that fill plug using a 3/8" ratchet(it fits in the square). go to the top of your motor and look behind it way below your intake manifold from the passenger side. On the back of the tranny case you'll see a sensor with a plug. there is 1 10mm bolt holding that speed sensor in place. take it off(little gear on the end of it so you know what you removed( ). fill your tranny oil by using a long funnel to this spot. once the fluid starts coming out the lower fill hole your fine. put fill plug and speed sensor back on and your done. The fluid line is basically right at the bottom of that fill plug. hth
Old Jan 28, 2002 | 07:24 AM
HX_Guy's Avatar
Default Re: tranny oil flush help (Lip)
Hmm, on my tranny...the drain plug has a "square" in it (for use with a 3/8" rachet) and the fill plug is a 17mm bolt. I use the fill plug to fill the tranny with fluid...no need to put the fluid thru the speed sensor.
Old Jan 28, 2002 | 07:33 AM
Lip's Avatar
Lip
Default Re: tranny oil flush help (HX_Guy)
Don't be so technical. it would be really tough to put a 3/8" ratchet On an inset square plug
its easier to fill from the top then it is to use the normal fill hole. its a pain in the *** to get fluid into the hole when your containers and funnels don't like running fluid against gravity. I personally am able to pump my fluid in rather then use the speed sensor hole. Its just easier this way...not impossible. by the way....that speed sensor is shown at the bottom center in black of this photo
Old Jan 28, 2002 | 02:27 PM
Toda Party's Avatar
here's another pic i took recently..drain (red circle)....fill, (green circle)...done.
i just used a funnel with a tube extension to run it into the fill hole cuz its sorta hard to get to.
Old Jan 28, 2002 | 02:29 PM
CPR's Avatar
CPR
Default Re: tranny oil flush help (Toda Party)
The bolt your holding...what's that for?
Old Jan 28, 2002 | 02:34 PM
Toda Party's Avatar
Default Re: tranny oil flush help (CPR)
that's the drain bolt, it goes where the oil is pouring out of, i just held it up so people can see what it looks like
Old Jan 28, 2002 | 02:39 PM
B18C5-EH2's Avatar
Former Moderator
Loved
There is a MUCH easier way to fill the tranny by just filling through the VENT tube that's located on the TOP of the tranny.
Anybody got a pic of the TOP of the tranny? I could point it out then. It's a pretty small hole, so you'll need to be patient. This way you SURE not to mess up and under/over fill and spill shiet.
Old Jan 28, 2002 | 02:47 PM
Trey's Avatar
25 Year Member
Default Re: tranny oil flush help (B18C5-EH2)
I can't believe YOU just said that.
Old Jan 28, 2002 | 04:08 PM
Toda Party's Avatar
yah the speed sensor? I watched someone do it that way, and it just seemed so cluttered and stuff to get to...Its not really too much harder this way...although i did do it with a friend with the wheel off, but, I had just bought a creeper, and I had to have an excuse to use it
Old Jan 28, 2002 | 04:20 PM
morepoop4u's Avatar
how often do you change tranny fluid (yrs/mile)
Old Jan 28, 2002 | 04:29 PM
nEoMuGen's Avatar
Default Re: tranny oil flush help (morepoop4u)
Toda Party:
Where can I get those gloves? I have a pair of mechanical gloves, but they don't give me the "touchy" feeling.
Old Jan 28, 2002 | 04:42 PM
Default Re: tranny oil flush help (nEoMuGen)
thanks guys! i'll get the mtf and tranny funnel tomorrow. this gives me a good excuse to use the new ac jack!
you can get the surgical gloves at pep boys, autozone, home depot, etc.
Old Jan 28, 2002 | 08:30 PM
Toda Party's Avatar
Toda Party:
my friend's mom is a nurse, he's got boxes laying around in his garage, i took a couple pairs
slor209
Feb 6, 2007 05:38 PM
5poonhatch
21
Sep 17, 2006 11:26 PM
CivicRaping
Mar 26, 2005 09:55 AM
b18cEF9
May 10, 2004 02:42 PM
dallandra
May 5, 2002 02:45 PM
