Transmission Oil Change
Hey was up i just changed my clutch and i drained my tranny oil. And i dont really know how to put new oil in. I heard you take off your speed sensor and put it through there but i did that and it looks like oil doesnt go in there. I have a JDM B16A tranny with lsd. Can some one tell ne how to intall new oil into my tranny. ANything will help. Thanks.
Re: Transmission Oil Change (92Hizzle)
Dipstick from the tranny? If you think there is a dipstick in the tranny then you need to stop posting right now.
There is a fill and drain plug. Fill is on the left side of the tranny, drain is in the bottom, this is looking at the tranny from the passenger side.
there is no dipstick but whatever. If you look at the tranny from under the car with you facing the rear of the car the draing plug is on the bottom of the passenger side. But where do i fill it.
Re: (5poonhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5poonhatch »</TD></TR><TR><TD CLASS="quote">there is no dipstick but whatever. If you look at the tranny from under the car with you facing the rear of the car the draing plug is on the bottom of the passenger side. But where do i fill it.</TD></TR></TABLE>
I know, he doesn't know what the hell he is talking about
Re: (5poonhatch)
the drain is a 17mm, and fill is a 3/8 ratchet plug. or they are oppossite, cant remember off hand, also if you have a lsd. they make certain fluids for them
Re: Transmission Oil Change (5poonhatch)
Here ya go simple search man... the pic is from an ex but the bolts are the same on the b16 tranny i just changed the oil on my b16a2 recently...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Hizzle »</TD></TR><TR><TD CLASS="quote">pull the dipstick for the tranny, grab a funnel and pour it in the hole.</TD></TR></TABLE>
lol^
easiest way is use a funnel with a long *** flexible hose, and pour till it comes dripping back out the hole
lol^
Re: Transmission Oil Change (melsers)
if you use a funnel on the fill hole, pull the hose out every once and a while, because the funnel hose will block the hole. you'll be filling and filling, with no real dripping, and once you pull the hose out...tranny fluid will spew out.
Single cam 5-speed trannys take 1.9 qts
are b16s like, 2.2 or somthing?
Location: San Diego to Palm Springs Runnin Things, CA, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.Dappa »</TD></TR><TR><TD CLASS="quote">Here ya go simple search man... the pic is from an ex but the bolts are the same on the b16 tranny i just changed the oil on my b16a2 recently...
ok im still a lil confused this is a pic from looking at the bottom of the car...what im confused about is where you inster the new trnny oil?
thanx in advance
thanx in advance
take the fill plug out and put a hose in it that runs up to the top of the car. attach a funnel and pour in. Its not that hard. Did it myself for the 1st time, and the hardest part was getting the fill plug loose.
you can also get a pump and pump the oil thorugh the hose and into the filler hole.
tranny dipsticks are only available in special "clutchless" trannies aka automatic.
Re: (ATEJ8FTW)
I am pretty sure that automatic transmissions do have clutches, I guess that is the reason for the quotes, but ur right haha automatics are the only ones with dipsticks
Re: Transmission Oil Change (teamvirus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus »</TD></TR><TR><TD CLASS="quote">it looks hella hard to put it in....i go through the speed sensor </TD></TR></TABLE>
is it better or worse if u do it through the speed sensor or the fill plug or does it not matter?
Re: (solerizr)
the hell? I always filled it from the top of the tranny where there' s metal stem topped with a rubber cap. The fill hole is small, but with a funnel it's much easier than going from the fill plug from the side or removing the speed sensor.
Anyways. Use Honda MTF
