pumping oil into tranny
there is 2 plugs on the side of the tranny...the drain plug is just a reg. 3/8 rachet that you put on there and the other plug is the fill/check plug which is i believe a 17 or 19mm...u can also fill thru the VSS if you want
the VSS is located on top of the tranny, near the passengerside inner axle....the filler/check plug is on the side of the tranny, above the drain plug, and also next to the inner passenger side axle
jeezyskillz
13
02-06-2007 06:53 AM
