Official Prelude Weight Thread
Pretty good thread.... if you don't mind, do a search for other posts in the past pertaining to this and post your findings.
I'll stick this in the FAQ's if enough info is given.
Front and rear bumper beams - 65 lbs.
ABS - 25 lbs.
CC - 3 lbs.
Rear seats, rear seat belts, rear seat supports - 30 lbs.
Sun roof and motor - 45 lbs.
PS - 15 lbs.
Trunk interior panels - 15 lbs.
All sound deadening - 30 lbs.
My optima battery - 45 lbs.
ABS - 25 lbs.
CC - 3 lbs.
PS - 15 lbs.
The ABS system weighs 25 pounds? That seems high . . . .
intake resonator & vacuum box - 4.15 lbs.
front vibration damper - 8.3 lbs.
rear engine mount weight - 2.55 lbs.
spark plug cover & wire stays - .35 lbs.
ATTS & control unit - 37 lbs.
balance shafts & belt - ~8 lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione »</TD></TR><TR><TD CLASS="quote">The ABS system weighs 25 pounds? That seems high . . . .
the pump is heavy
the pump is heavy
The ABS is definately 25 lbs. for the pump.
Sunroof assembly (w/ drain tubes and bolts) is 34 lbs.
Sound deadening material totals about 15 lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
Sound deadening material totals about 15 lbs.</TD></TR></TABLE>
Are you 105% sure about that?
Unless you guys have PERSONALLY weighed the items, then please don't post what you 'think' or 'heard' they weigh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">
Unless you guys have PERSONALLY weighed the items, then please don't post what you 'think' or 'heard' they weigh.</TD></TR></TABLE>
Yes, I took it out, put it in a garbage bag and put it on the scale and it was 15 lbs. I didn't get 105% of it, so that's why I said 'about'. I didn't get the piece in the center under the dash or the 2 pieces on the rear wheel wells.
There is already a thread about this.
https://honda-tech.com/zerothread?id=1172229
Here's an informative 6 page thread on weight reduction.
https://honda-tech.com/zerothread?id=882968
hondacivic4g
Dec 13, 2003 11:54 PM
DevinW
Nov 4, 2002 08:40 AM
