DSM Fuel Injectors
Old Jan 27, 2002 | 07:05 PM
Hayasa15's Avatar
Default DSM Fuel Injectors
Hey guys i just won a set of 390cc injectors off ebay for about 10 dollars. Does anyone know if they will work with a mini me or a d16z6 swap? Also do i need a different resistor box to run these?
Old Jan 27, 2002 | 07:27 PM
Denny317's Avatar
Default Re: DSM Fuel Injectors (Hayasa15)
are you running turbo?
Old Jan 27, 2002 | 08:14 PM
Mugen Dom's Avatar
they will work with it but y they are for a turbo car if u put a turbo on u can use them with a afc cause they will flow to much with the turbo anyway also and yes i believe u need the resister still
Old Jan 27, 2002 | 08:17 PM
AbaZ's Avatar
Yes, but you will need to run a differnt Fuel managment device.. a stock ECU will make those 380cc injectors run so rich.. I use to have 380's in my car and it was horrible.. and I hope your plan is to put a turbo on? since stock injectors w/ a regulator can be ok at 200whp.
I currently run 450cc injectors on my Mini-me turbo with a Zdyne Gold Secu..
Jeff
[Modified by AbaZ, 5:18 AM 1/28/2002]
Old Jan 28, 2002 | 03:26 PM
SiR Kid's Avatar
New User
Default Re: DSM Fuel Injectors (AbaZ)
AbaZ, did you have to run the resistor box with your 450cc injectors in you car? I don't have mine in, and it SEEMS ok.... but I'm worried.
Old Jan 28, 2002 | 03:45 PM
AbaZ's Avatar
nah, the 1g DSM 450cc injectors work fine in my car.. they have a resistor box just like in our cars... I even think the 2g 450cc injectors have the resistor pack also.
jeff
Old Jan 28, 2002 | 06:50 PM
SiR Kid's Avatar
New User
That's just it... i don't have my reisitor box installed right now... should I?
Old Jan 28, 2002 | 07:23 PM
Hayasa15's Avatar
Default Re: DSM Fuel Injectors (SiR Kid)
Which resistor box are you guys talking about?
Old Jan 28, 2002 | 07:24 PM
AbaZ's Avatar
Why did you take it out in the first place? our Stock SI electronics uses them. If you dont know what one is.. its the little 3 by 4 metal looking thing (Kinda like a heatsink) chiling on your LH strut area.
Jeff
bigtom388
Oct 16, 2008 04:33 PM
jdmsohc94
Apr 13, 2008 03:22 PM
crispydee
Aug 1, 2004 02:52 AM
JALOP B16
12
May 11, 2002 06:48 AM
