NEED FAST RESPONSE... oil pan issue
last night i hit a pothole and my oil started leaking on the freeway, eventually it all leaked out and my car stalled. I tried adding more oil but it just came right back out from the oil pan. now my question... could that have cracked my oil pan? or is it something less serious than that. please help
ya thats bad, your motor might be fucked now, but as said jack it up ibet the oil pan is either cracked real bad or seperated from the block a little
Well first off, don't turn the car on at all. Secondly, jack up the car and see if you notice a crack. If it's not cracked, check around the gasket and see if it's still leaking there. If it is crack, it's a pretty easy job to do.
Buy a new oil pan and gasket, install. It's as easy as it looks, remove the bottom peice of the header, remove the oil pan bolts, bolt the new one on, with the gasket, reattach, add oil. Done.
yea theres a huge crack down the middle... now about my motor being seized... i noticed a small amout of smoke comming out of the head... could it be serious? it wasnt a large amount or anything.
Well, only way to tell really is to put oil in it and try starting it up. Most likely your engine is garbage though and you will need to replace at least the block/lower end.
