Help...Sticky Throttle?
Old Apr 3, 2005 | 06:04 AM
1QWKGS's Avatar
New User
Default Help...Sticky Throttle?
I having a problem with my throttle being sticky when I first press the accelerator. If I blimp the throttle, the stickyness is gone until the throttle plate closes and its at idle, then it is back to sticky. This problem only happens when the car is on, because I tried it with the car off and the gas pedal is smooth. I also disconnected the throttle cable to see if it was that, but with the car on, I turn the throttle plate by hand and the initial turn is difficult. It seems to be stuck until you break the vacum. Could the throttle body be dirty? or Could the it be the tps?
Old Apr 3, 2005 | 06:11 AM
.water's Avatar
Default Re: Help...Sticky Throttle? (1QWKGS)
this is same happend to my mom's 00accord. yes i figured out that dust&carbon where butterfly touches (when close)...i try to clean them, i didnt know what to use..so it still kinda sticky during cold weather is there any good cleaner i use safe?
Old Apr 3, 2005 | 06:45 AM
FormulaGSR's Avatar
Default Re: Help...Sticky Throttle? (Chris DC2)
you can use damn near anything. I used carb cleaner when i was working at ford. It would be best to go ahead and take off you TB before you try to clean it.
Old Apr 3, 2005 | 07:01 AM
.water's Avatar
Default Re: Help...Sticky Throttle? (FormulaGSR)
y? is it bad when it goes down to M/F ?? what if i just spray on towel and clean..thats ok??
Old Apr 3, 2005 | 07:11 AM
the buddha's Avatar
just leave the car car on and spray carb cleaner and
****** the throttle a couple of times might take a few
times good luck
Old Apr 3, 2005 | 08:23 AM
1QWKGS's Avatar
New User
Default Re: Help...Sticky Throttle? (the buddha)
thanks for your input, i'll try that.
Old Apr 3, 2005 | 01:44 PM
non-VTEC's Avatar
sounds like a dirty throttle plate........don't use carb cleaner on a throttle body fuel injected car........this is 2005 not 1975.......they have the proper throttle body cleaner at the parts store......
Old Apr 3, 2005 | 10:29 PM
.water's Avatar
Default Re: Help...Sticky Throttle? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a dirty throttle plate........don't use carb cleaner on a throttle body fuel injected car........this is 2005 not 1975.......they have the proper throttle body cleaner at the parts store...... </TD></TR></TABLE>
well..ok Do you know what should i use? name&barnd for integra's
Old Apr 3, 2005 | 11:52 PM
jdm_cars's Avatar
take off your throttlebody, clean as much as you can with carb cleaner, use Green 3M dish scrubber to clean off the black gunk.
If you want it like new, use 1500-2000 grit sand paper and polish it with this, works great if you want to clean up your TB like new again.
shabam
Dec 9, 2007 07:52 PM
philosofy1
Jan 10, 2007 07:46 PM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
miahmouse
Oct 7, 2002 09:24 AM
