Quick and Easy--WILL A LS HEADER FIT A GSR??--ASAP
Looking to buy an GSR which is currently Turbocharged, but if I buy it will be NA.
Hence I need to find a temp. header to drive home, so will a LS Header fit a GSR?
Also will I need a whole new oil pan, or can the tap be plugged?
94-99 gsr headers and exhausts are interchangable
00-01 gsr / 97-01 type r / 94-01 non-vtec headers and exhausts are interchangeable
so the short answer is no, unless you're referring to an 00 or 01 gsr.
Okay thanks for clearing that up.
What about the oil pan, does it have to have a new one or can it be plugged, or the line blocked.
Just to let you know some companies headers the exhaust flange for a LS will not fit the gsr or type R pecause the block comes out 4 mm or so. I am currently using a HP but I had to trim off the botttom of the flange to get the LS to work on a GSR.
The guys are also refering to the cat connection which they showed you pictures of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth »</TD></TR><TR><TD CLASS="quote">Check it out yourself.
damn thats nice , how they did that
</TD></TR></TABLE>damn thats nice , how they did that
[QUOTE=sonik_da_teg]yes they will fit i have gsr headers on my ls <<[/QUOTE yes they will fit i have gsr headers on my ls ]
He's not trying to put a gsr header on a LS
He wanted to put a ls header on a gsr. And although the bolt pattern is the same what I said was THAT THE BLOCK OF A GSR STICKS OUT A LITTLE CAUSING SOME HEADERS NOT TO BE ABLE TO SEAT ADAINST THE HEAD, AND ON THE OLDER GSR'S THE CAT POSITION MAY BE DIFFERENT THAN THAT OF A LS.
Anyway I'm done go find out for yourself.
yes my dc 4-1 ls header barely clears my 94 gsr motor. Im using my entire ls catback. I might have to take it to a muffler shop so they can bend it. As far as length you can use any header on any integra, as long as you keep the same cat and exhaust length to go along with the header. Everything must match.
