Cooling ?
Running B16 wt turbo, using stock civic rad , also using pusher fan mounted on opp side... took car out the other night after boost run, temp went up past the halfway mark, shut off, havint ran since... fan runs alot , car warms up quick, should i be using a aftermarket 2 or 3 row...what do most run??
