cooling fan not coming on....
Old Dec 4, 2007 | 06:45 PM
T9U4ReBgO's Avatar
Default cooling fan not coming on....
when i finished up my turbo install i started my car to make sure i had no leaks and what not. well i noticed my car got to running temp and the fan never kicked on so i let it run and run and still it never kicked on buy my car never started running hot, it just stayed at the normal temp....y could this be ive checked a few times since then and still have never seen it come on...it is plugged in and worked fine before but like i said it doesnt run hot either?...should i just straight wire it to be on the safe side..has anyone else had this problem...and help is appriciated...
Old Dec 4, 2007 | 06:55 PM
bluedragon's Avatar
Default Re: cooling fan not coming on.... (T9U4ReBgO)
well I had a simaler problam my fan would turn on either a so I changed from a pull to a push fan works great now. but what you can do check make sure nothing burned out or has a short in the wiring. also check to coolant level thjis could also be why its not kicking in because it's not reading a good level.
Old Dec 4, 2007 | 07:02 PM
T9U4ReBgO's Avatar
Default Re: cooling fan not coming on.... (bluedragon)
ok ill try that...thanks...its just wierd that it isnt running hot tho...i mean it runs fine just the fan wont kick on....
Old Dec 4, 2007 | 11:01 PM
T9U4ReBgO's Avatar
ttt any other suggestions?
Old Dec 5, 2007 | 12:40 AM
RC000E's Avatar
Well, I mean the fan uses a thermal switch....if the car isn't hot, then that would explain why the fan isn't on. It isn't on a timer. Test the fan switch, then test the fan...if both are fine, then there's nothing to worry about.
Old Dec 5, 2007 | 02:52 AM
T9U4ReBgO's Avatar
Default Re: cooling fan not coming on.... (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Well, I mean the fan uses a thermal switch....if the car isn't hot, then that would explain why the fan isn't on. It isn't on a timer. Test the fan switch, then test the fan...if both are fine, then there's nothing to worry about.</TD></TR></TABLE>
I understand it is temp controlled I don't understand how I can let my car idle for a good while and it never start running hot and the fan never come on?
94hondaccord
Apr 11, 2012 01:50 AM
724chris
Oct 12, 2010 09:49 AM
la_teta
Oct 5, 2010 02:49 PM
EFOwNzALL
Jun 24, 2008 09:09 AM
Foxcow
Jul 29, 2004 06:27 AM
